GC 2610 w/ sticky reverse pedal....
   / GC 2610 w/ sticky reverse pedal.... #1
ozsevenzero
Massey GC 2610 TLB
My GC has roughly 90 hours on it and lately the reverse pedal sticks and stays in position until i remedy the situation with my foot by pressing the forward pedal. No biggie, but once in a while i take my foot off expecting it to return to the neutral position and it keeps going (wasn't too funny when the wife tried to move it and almost took out a lawn chair). Weird thing is that it doesn't do it the opposite way.
My question is this; is there any adjustment or major lubrication i should be doing to the linkages? I have sprayed the linkages with some lubricating oil and it still sticks.
   / GC 2610 w/ sticky reverse pedal.... #2
At the risk of the obvious, you have greased the zerk at the pivot, under the pedals, correct?
Yep, lubed everything possible.....only sticks when using reverse for more than a brief moment.
   / GC 2610 w/ sticky reverse pedal.... #4
Could be a spring tension adjustment.
   / GC 2610 w/ sticky reverse pedal.... #5
Check with the dealer if there is a service bulletin for the problem. There is one for the 23xx and I do not know if it covers 24xx,26xx.
Doug
10 - 3/16in Plate Steel Sheets (A55973)
10 - 3/16in Plate...
Toro San Pro Bunker Rake (A56857)
Toro San Pro...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
flooring (A55758)
flooring (A55758)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
