AxleHub
Elite Member
Greetings,
I've owned my GC1715 since June of 2015. And currently I have about 200 hours on it.
Unit has been incredibly dependable and durable for both summer and winter issues of Wisconsin.
A year or more ago - while snowplowing with my snow edge on my fel - I surprisingly developed a flat front tire (turf tire) on our long concrete driveway. Managed to get it back to the top - took wheel off and took it in for repair. Turns out the Valve stem was inside the tire and still worked properly (no damage to tire). But because a flat is a major pain especially in the winter - I had them put on a new valve stem.
Now this year during our extensive snow season this year - I again had the same thing happen. Again - the valve stem was inside the tire and this time I had them put on a steel valve instead of rubber. Apparently - something is happening that forces the rubber stem in the wheel and then of course - flat tire. I don't know if others have experienced this - but it seems the steel valve will be a considerable improvement - because it actually fastens with a washer and nut on the outside and inside. Once is a fluke - but twice on the same tire and same conditions - indicates an issue to be rectified.
The steel valve doesn't protrude any further out than the rubber one did - but it should take substantially more pressure before being forced inward.
I'll also add that in this 3.5 years of ownership - I've never had air decreases of tire pressure at all - never required filling air in tires - and yes - the unit is kept outside on the southern side of the property in sunshine. I saw no indication of sun fade or sun aging on any part of the tractor or tires at this point - however I do have a cover I put on the tractor - so it certainly appears the valve stem is the focus of the problem and just on the one side.
If it happens again - I think then I go to acquiring a spare wheel rim and turf tire so I can easily switch and not lose use and time.
