GC1710 vs GC1720
   / GC1710 vs GC1720 #1
madhatter
Sherwood Park,Alberta,Canada
2015 Massey GC1710
Other than the 2.5HP and bit more hydraulic flow, is there anything else different between the GC1710 and GC1720? Is it just through RPM's? Injector pump?
Wondering if the difference is noticeable for the extra 1K.
Thanks
   / GC1710 vs GC1720 #2
If like the 2410/2610 predecessors...exact same machine.
Fuel pump adjustment only...was told by my dealer...I then bargained myself a 2610 at the price of 2410 !
It does run at a slightly higher RPM on mid and back pto's.
   / GC1710 vs GC1720 #3
I had a 2310 at one time and I was pretty impressed with the power of it, especially the BH. Seeing the specs of the two models, what is suspect to me, is developing hp by 2600rpm and 3000pm between the two models. If those numbers were the same then the difference would be more credible. I could be wrong, but I doubt there is much real world difference.
What I would suggest is emailing Massey with the specific questions. In the past I had emailed them and received pretty quick replies. Might be worth a shot. Also, post if you receive an explanation as their answer would be interesting.
   / GC1710 vs GC1720 #4
I've got a 1705 on the way myself, I couldn't justify the bump in rpm's/power though I wouldn't mind being able to tweak the 1705 to reach the extra 400rpm and hp numbers.
   / GC1710 vs GC1720
That's what I was thinking. If it is just a injector pump tweak... however I am surprised no one else has a write up on how to do it if it is just that. After warranty is over of course.....
   / GC1710 vs GC1720 #6
I believe there are some additional differences...for example the turn signal/blinker lights on the 1710 do not have the metal guard, the 1720 does. You'd need to talk with a dealer or at least go look at them yourself. There was almost a negligible different in price between the GC2400 and GC2600, but when they switched over to the 1700 series, they took some cost of the the lower cost model to make more of a difference between the two.
   / GC1710 vs GC1720 #7
If you run the 1705/1710 at a higher RPM, won't the PTO's run at a higher RPM also though? You'd be about 15% high, so the rear 540 would really be about 620 and the mid 2000 would be just over 2300 rpm. I don't know how big deal that is. I doubt the extra couple HP will be noticeable for just loader work, but could make a difference with powering attachments I suppose.
   / GC1710 vs GC1720 #8
I was just looking at the specs and it looks like all the models from the 1705-1720 reach 540rpm at 2000RPM.
   / GC1710 vs GC1720 #9
I think you may be reading the brochure incorrectly. Its has 2 numbers, the rear PTO RPMs and the mid PTO RPMS, neither of those numbers is engine RPMs. Each model will provide those standard output rpms (540 and 2000) very near to the max engine RPMS 2600 for the 1705/1710 or 3000 for the 1715/1720.
   / GC1710 vs GC1720 #10
Oops, you are absolutely correct, dunno why I saw that, LOL. Thanks for correcting what I posted.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
LaneShark LS3 (A56469)
