Gear drive vs hydro
   / Gear drive vs hydro #311
Heck, why not use a Danierls senior orfice meter. That way you can change the orfice while the equipoment is operating.:D
   / Gear drive vs hydro #312
I had an opportunity to see a gear tractor in operation today. {snip}
It is like welding to a degree. If an AC only buzz box does all you need and you don't want or need better then be happy don't worry keep your buzz box and let others go MIG, TIG, flux core, or...
Pat
From what you wrote my guess is that what you in fact saw was a heavy handed operator, the tractor having a gear transmission was incidental.
By your own analogy a competent weldor can achieve much better penetration and generally better results using a stick "buzz box" than a klutz with a super duper mig rig and a push/pull gun.
IOW, it isn't ABOUT the equipment and in many cases feature encumbered gear inhibits learning & skill development.
Running MIG "just like a hot glue gun" sometimes produces a pretty wash weld, but a pretty weld without good penetration is harder to do with a stick.
("Playing" an i-pod can get a lot of music, but will never make someone a musician).
   / Gear drive vs hydro #313
. If I were a gear tractor I might be losing rpm, but I wouldnt be wasting power pumping fluid into the sump thru a relief valve.]
larry[/QUOTE]
Right, you'd be doing it wearing out your clutch.
Jake
   / Gear drive vs hydro #314
larry
Jake
Yeah. I love post count builders, I mean threads like this. :)
   / Gear drive vs hydro #315
larry
Jake
No, id shift to a lower gear if the bog became critical. Not too convenient, but much more so than changing a clutch.
larry
   / Gear drive vs hydro #316
I was thinking that too. No doubt in my mind tho that an HST would have eased the situation regardless of operator skill.
larry
   / Gear drive vs hydro #317
some of us are trying to make an occasional point here, will, while waiting for the next drinking game to start. when it's too early for that, it's kind of like 'king of the mountain'.
jake
   / Gear drive vs hydro #318
larry
and at least he could have gotten almost squished in a smoother motion..
(glad he didn't)
jake (the guy that was polking around a running snoblower yesterday) 'well it wasn't turning so i thought i'd give it a spin...'
   / Gear drive vs hydro #319
I guess we will all buy what we think best suits our applications. The bad part is....... what we think is best for us also should be the best for everyone else. Both transmissions have their good points and bad. I know my choice and the reason for that choice,but my choice should have nothing to do with your choice. I would imagine that the gear vs hydro debate will go on again in the not so distant future. Albeit on a lesser intellectual scale than this time.
Sincerely, Dirt
   / Gear drive vs hydro #320
larry
Weren't most of the heavy handedness problems with the loader controls ?
I lack confidence working around OTHER PEOPLE on tractors anyway, but I think my self preservation instincts have a better chance if I see a tractor lurching towards me than one gently creeping up to squeeze me softly against a wall or push me gently over a ledge )-:
Again, this is about the operator not the tractor - but I would still prefer that the tractor NOT mask his/her incompetence.
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
UNUSED FUTURE 32" CAT305 EXCAVATOR RAKE (A57193)
UNUSED FUTURE 32"...
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2013 Ford Taurus Sedan (A55853)
2013 Ford Taurus...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
