gear shift problem ...
   / gear shift problem ... #1
Gedfish
Purga / Mutdapilly, Australia
Ford 4110 Series 2, 1988 Kubota B7510, 2006
Hi there - My 4110 2WD diesel has high & low range & reverse on the left hand column shift and 4 shift positions on the right hand side column shift. 3rd & 4th gear on the right hand column shift will not engage in either high or low range. Any clues?? Thanks, Ged
   / gear shift problem ... #2
I have a New Holland TB110 having problems getting it out of reverse.
   / gear shift problem ... #3
I have a New Holland TB 110, my problem is I can't get it out of reverse.
Barry - Since I posted this I've been in contact with the dealer (30 yrs on Fords). He assures me that it is just a minor adjustment issue with the connectors under the s'wheel just behind the p'steering unit. At worst - the top may need to be taken off the gear housing for minor internal adjustment. Definitely no whole gear box rebuild etc. He argues that it is minor because I can still use the other gear positions. Cheers, Ged
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
2014 Peterbilt 388 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2014 Peterbilt 388...
2008 TEREX TRAILER LIGHT TOWER (A58216)
2008 TEREX TRAILER...
Lely 1250 3Pt. Fertilizer Spreader (A57149)
Lely 1250 3Pt...
UNUSED FUTURE CYHC MINI HYD 29" SIDE SHIFT FORKS (A58376)
UNUSED FUTURE CYHC...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
