gear shift problem ...
   / gear shift problem ... #1
Gedfish
Purga / Mutdapilly, Australia
Ford 4110 Series 2, 1988 Kubota B7510, 2006
Hi there - My 4110 2WD diesel has high & low range & reverse on the left hand column shift and 4 shift positions on the right hand side column shift. 3rd & 4th gear on the right hand column shift will not engage in either high or low range. Any clues?? Thanks, Ged
   / gear shift problem ... #2
I have a New Holland TB110 having problems getting it out of reverse.
   / gear shift problem ... #3
I have a New Holland TB 110, my problem is I can't get it out of reverse.
Barry - Since I posted this I've been in contact with the dealer (30 yrs on Fords). He assures me that it is just a minor adjustment issue with the connectors under the s'wheel just behind the p'steering unit. At worst - the top may need to be taken off the gear housing for minor internal adjustment. Definitely no whole gear box rebuild etc. He argues that it is minor because I can still use the other gear positions. Cheers, Ged
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
SUV (A59231)
SUV (A59231)
Huskee 20 Ton Wood Splitter (A57453)
Huskee 20 Ton Wood...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
