Gelled Fuel
   / Gelled Fuel
I followed Bird's post to the PowerService web site and they have a product called Diesel 9-1-1 which can be used to re-liquify gelled fuel.
   / Gelled Fuel #32
Yep that's the stuff I was thinking about and posted but couldn't remember the name. It works but it takes awhile.
   / Gelled Fuel #33
<font color=blue>...can be used to re-liquify gelled fuel...</font color=blue>
If you did nothing other than let the tractor sit until warmer temps... the gelled diesel fuel will automatically revert back to its normal liquid state...
This would be no different than letting a block of ice thaw out... and it would automatically return to it's liquid state of water...
Adding more diesel fuel to a "gelled state" will accelerate the process, but adding an additive or kerosene will also "winterize" the mix when the process is complete...
   / Gelled Fuel #34
I use Power Service, but I wonder if something like the 9-1-1 product might be a good idea for keeping water out of the fuel? Does anyone use something like this in a preventative manner, or just when a problem crops up?
Bob Trevithick
   / Gelled Fuel #35
JM3:
When I lived back in Alberta we had a warm winter that changed to -30/40 c overnight. There were dozens of transport trucks comming from Vancouver parked allong the roadside.
Egon
   / Gelled Fuel #36
Has anyone tried to contact the local bulk fuel supplier for his thoughts and products to alleviate the gelling problem?
Egon
   / Gelled Fuel #37
Bob,
No need to do that. The power service does that already. The only time you would need the 911 is if you are gelled. Also from past experience don't even try and run diesel that has water in it. All you do is keep plugging up your filter and it's extremely hard on the injectors.
   / Gelled Fuel #38
<font color=blue>... Also from past experience don't even try and run diesel that has water in it.</font color=blue>
Yeah, but how do you know if there is water in it? Maybe the place you bought the fuel has water in their tank, or maybe condensation has occured in your own tanks? Or am I worrying about nothing? /w3tcompact/icons/smile.gif
Bob Trevithick
   / Gelled Fuel #39
Minute amounts, you may NOT know. Slightly larger amounts may be seen in the fuel filter if you have the transparent filter bowl like a lot of us. And if you don't SEE it, you'll know when the tractor quits or starts running rough./w3tcompact/icons/frown.gif/w3tcompact/icons/wink.gif
   / Gelled Fuel #40
Does your tractor have a water in the fuel light on it?
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2014 LAMAR TRAILER (A52472)
2014 LAMAR TRAILER...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
