Generator question
   / Generator question #1
sarti
Central Illinois
Kubota L3901 BX2670
I know this is a tractor forum but I have a generator question and you folks seem pretty smart about things. I am going to buy a portable generator for my house and I would like to get propane(have a bulk tank for the house)
or tri fuel model. I noticed some models have idle control (alot more money)
Was wondering what pros and cons are and if the idle control is worth the extra money. The reason for propane is, I was without power for a week and got tired of fueling my small generator. I would like a larger one to run more of my house. THANKS
   / Generator question #2
The idle feature saves fuel when the load is low. The dual fuel arrangement is a good solution, for long power outages, we once had a nine day outage during and ice storm. All the locals were out clearing the r.o.w. of down trees. You couldn't get down the mountain for gasoline and the only local supply ran dry. Of course, if your propane tank is low when the outage starts, you'd better have a wood stove for backup. It helps a whole lot to have a cord of wood on hand for such an event, and a wife who can cook on a wood stove.
   / Generator question #3
I recommend you check out this link: Home Generator Systems, They have 7000 watt package deals which include a manual transfer panel with 11 circuits, remote manual start, propane, weather proof enclosure, etc., all for under $2,000.00. More expensive models have automatic start and automatic transfer from utility power.
Jim
   / Generator question #4
For your use I'd think that the idle control isn't necessary. You will be using the generator to supply power for your needs during a power outage. If your needs aren't requiring power, turn the generator off. I wouldn't want a generator running (even at idle) if I didn't need the power.
As far as the rest of the purchase/install, PM me or post a thread with questions. I've been living off-grid for about 30 years and have learned much through trial-and-error about generators, inverters, solar power and batteries.
Phil
   / Generator question #5
I have the idle feature on my Generator / welder. It works great to save fuel when I use it for welding or in the field when power tools are not running the engine idles down.
When used as a generator for backup power it never idles. If your buying one for backup power for your house you won't need the idle feature.
   / Generator question #6
I have a 12K Coleman Powermate and the idle feature only allows it to idle when there is no load. If I plug in a worklight with a 40 watt bulb the generator comes off idle and runs at the same speed as when I am running the generator at full load. Don't know if they all work like that or not.
Dave
   / Generator question #7
Not all eco-throttle, or idle down gennys work like that. The inverter type such as the uber popular honda eu2000i idles up as needed to meet the demands of the load. I think it has to do with whether the genset has an inverter to make the frequency or relies on revolutions. Our power in the US is supposed to be 60 cycles per second which is the same as 3600 rpm which is what the typical genset is running at while making power. The all or nothing type idle down gensets must be set up to always deliver 60 Hz to any load so unless there is zero load the genset must spin 3600, even for a light bulb.
If you are expecting this genset to spin up a big load like a heat pump or a welder then I propose that having the engine reved up to 3600 rpm at all times offers a flywheel effect and the ability of the genset to supply this huge power load cleanely and quickly is superior. The alternative is a lazily idling engine that gets hit with a huge whallop of full throttle and supplies low frequency power, low voltage, for as long as it takes the engine to rev up.
I vote for no idle-down on a home backup generator. I vote yes for an idle-down feature on a camping generator equipped with an inverter.
   / Generator question #8
Dave
Some of the generators on the market are actually alternators producing DC and then generate the AC power with an inverter. The Honda EU series are this way. Very quiet. The motor RPM's increase with the load. In other generators (especially bigger ones) the RPM's are linked to the AC frequency (60 hertz in North America). 3600 RPM is 60 hertz. Sometimes they have a gearbox between the engine and generator such that the engine can run at 1200 RPM (less wear and tear on the motor, but losses in the gearbox).
Hope this helps some,
Jim
   / Generator question #9
My 15Kw (continuous) Generac works the same way.
No load, and I mean none at all, and it will idle. Even a very small load will make it run full out.
I have been considering adding an hour meter to it, but I am afraid even that load will cause it to run full out.
   / Generator question #10
I've got a tri-fuel generator and love it. We have had some extended outages and not having to refill the gas tank has been a great feature.
One thing to keep in mind with tri-fuel generators is that they are often "rated" for output while using Gasoline. Propane has less energy than gas. So if you have a 10,000 watts tri-fuel generator and it is rated at 10,000 watts using gas, its output when running off your propane tank will likely be about 9,000 watts. If you run it off of Natural Gas, that contains even less energy than propane and needs to be downrated even further. That said, if you are buying a generator and size it based on your needs, based on the 'rated' output, you may need to UP SIZE your purchase to a slightly larger unit.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Sedan (A59231)
Sedan (A59231)
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
13042tx (A55973)
13042tx (A55973)
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
