Getting gravel out of the pickup
   / Getting gravel out of the pickup #11
Sounds like a lot of satisfied LoadHandler customers. I've thought about getting one of these for the FIL for a birthday or father's day thing. Never got around to it. What model LoadHandler are you guys using? I see there are now two models - one's heavier duty. He's got a heavy F250 and we put some pretty good loads in it.
I've seen ads for the load handler but was skeptical. Sounds like it works, so I'll probably order one. The CFO (wife) helped me clean out the truck yesterday, so getting the money shouldn't be a problem this time. Until then I'll throw a tarp in the back because I have an extra one laying around.
Thanks for the advice.
   / Getting gravel out of the pickup #13
A spray-on bedliner (line-x or Rhinoliner) will also solve this problem. There are no ribs. Has worked well for me.
Cliff
   / Getting gravel out of the pickup #14
I got the heavier duty one... better safe than sorry I thought.
I have an F350 and tend to haul heavy loads.
   / Getting gravel out of the pickup #15
When I get gravel with my truck, first I put a blue tarp down and then a sheet of plywood. You can shovel off the plywood easily then when most of the gravel is out, remove the plywood and pull the tarp out and the truck bed is clean and I am ready for a beer.
Kevin
   / Getting gravel out of the pickup #16
Richard,
My friend and I did it a bit differently than you. We did take a chain and hook to the front of the pickup and then raise the front up with my tractor loader, worked well as long as you don't worry about scarring the front bumper up with the chain. We did not turn it upside down though. Just lifted it up to about 30 degrees and backed up slowly spread it out pretty well.
   / Getting gravel out of the pickup #17
I'm another happy Load Handler owner / user. /forums/images/graemlins/smile.gif
Corm
   / Getting gravel out of the pickup #18
You might want to try one of these - I thought it was cool when I saw it - haven't tried it though
RAKE, TRUCK BEDLINR
Model: BLR-1
HH Item Number: 8711-343
Truck Bedliner Rake
- New, innovative product that revolutionizes
how you clean your truck's bed liner
- Constructed of recycled, high density plastic,
and covered by a Life Time Warranty, it is
tough enough for all jobs, and will not damage
- Often topsoil, gravel and sand are left in the
trucks bed liner, simply because it's just too
hard to clean
- Saves you time, money and aggravation
- Triangular, multi-profile shape fits all standard
rib type bed liners, and threads onto standard
broom or painter handle
- Select the appropriate side of the rake so that
the teeth align with the ribs in the bedliner
- Does an excellent job on nails, screws,
broken glass, bark mulch, snow, ice, topsoil,
gravel, wood chips, hay, manure, salt and
mud
Want to thank everyone for their "load handler" recommendations. Installed one today and it worked as advertised on about 1,000 lbs of gravel. It is one of those "wish I had thought of that" devices.
Next time, I'm going to throw a tarp down first to catch gravel that overflows on the sides. I was able to unload directly into my tractor bucket, saving me a lot of shoveling.
   / Getting gravel out of the pickup #20
Can you install a load handler on a bed that has a tonneau cover?
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A53473)
Quick Attach Skid...
2004 Chevrolet Silverado 2500HD Service Truck (A53422)
2004 Chevrolet...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
