Happy Gilmore
Veteran Member
- Joined
- Jan 11, 2014
- Messages
- 1,752
- Location
- Southeastern, MA
- Tractor
- Ford 5610 Ford 4630 Ford 3930 MFWD w/ 7310 loader Ford 3930 Kubota BX1500 Kubota RTV 900XT Kubota F2680E 72"RD Ford 4610 Kubota KX121-3
After stirring it up a bit remove a plug and look for metalflake in the track drive motor oil. Drive motors can be $7,000, any metalflake in the oil it's too late. Also smell the oil in the track motors, if it smells burned (I've not smelled burnt but "they" say it's un-mistakeable and unpleasant too) that's a bad sign, but not as bad as metalflake. Better check both sides. If the oil is recently changed you won't learn much from this. You will need to bring an 8mm (or 10mm?) allen wrench to remove the plug.
Thanks Sodo, I was really hoping to have one for Spring, found a candidate, but it's 5+ hours away. It's a 2012 with 6 way blade, cab and a low 240 hours. I can buy it for $39k
