Getting rid of scrap sheetrock
   / Getting rid of scrap sheetrock #1
jt7157
north central tennessee
new holland tc55da
I've heard several people say that burying sheetrock actually helps the ground by adding lime to the soil. And I've heard of people using a chipper/shredder to grind and spread unused sheetrock onto a garden. Has anybody heard of such a thing, and are there any harmful binding chemicals in sheetrock that one would not want in his ground? Thanks for the help.
   / Getting rid of scrap sheetrock #2
Hmm. Don't know about chemicals. Worth checking. If not I'd just bury it. I wouldn't chip or shred it as the dust would be dreadful, and probably not great for the equipment.
   / Getting rid of scrap sheetrock #3
I put 6 4'X8'X1/2" in my back driveway last year and it's all crumpled up now and makes great fill
Go for it :D
   / Getting rid of scrap sheetrock #4
Drywall contains gypsum, which can help break up dense soils like clay based soils and keep them from packing back together solid.
Fire retardant and water resistant drywall (Green board and Blue board) contain other additives, which may or may not be desireable.
I had heard you could leave the drywall out in the elements, and after a couple of rains, and driving over them, they will crumble, you can remove the paper (or a good deal of the paper), crush it up as fine as possible, then use it.
I have never heard of burying sheets or partial sheets of drywall? Anyone?
   / Getting rid of scrap sheetrock #5
I've tilled the scraps of drywall into my vegetable garden in the past. The paper will decompse, too, given time.
   / Getting rid of scrap sheetrock #6
I used to work at a sheetrock manufacturing plant. Water resistant sheetrock is made by adding ashphalt to the mix. Because of the gypsum all sheetrock is fire resistant.
I have used pieces of it in wet areas to dry them out. I had several areas that never dried out and would fill with water with any rain. Every time you ran over them with the tractor you got a mud hole. Well I filled them with old sheetrock pieces and now I have no problem.
By the way all that goes into sheetrock are gypsum, paper and hide glue to bind the cover paper to the gray back sheet.
   / Getting rid of scrap sheetrock #7
Man, the random tidbits of information that one can learn here on TBN is great :)
~paul
   / Getting rid of scrap sheetrock #8
I've used them in my clay garden in the past, along with lots of mulch tilled in over the yrs., it's no longer a 'clay' garden!
   / Getting rid of scrap sheetrock #9
as the other poster stated, sheet rock is gympsum with paper and glue. gympsum, also known as calcium sulphate, is the same gypsum found at the lawn and garden store in the fertilizer department. it can be used as a trace mineral additive (calcium, like anyone with limestone doesn't already have enough of that) or as a source of slow release sulfer.
only a soil test can tell you if you need these additives. here's a pdf file that tells all about it.
amp
  • Gypsum[1].pdf
   / Getting rid of scrap sheetrock #10
~paul
Another tidbit: Mashed up sheetrock (or bags of powdered gypsum)is also great for clearing up a muddy pond.
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
Sterling 9500 (A56438)
Gravely ZT XL-52 52in Zero Turn Commercial Mower (A59228)
Gravely ZT XL-52...
2022 Dodge Ram 4500 Miller 8,000lbs Wrecker Tow Truck (A59230)
2022 Dodge Ram...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
