Getting safety glass cut ??
   / Getting safety glass cut ?? #21
I used to work for a glass co we would take flat laminated glass 4x8' panels into the coal mine here in IL and cut whatever was needed for the dozers or rock haulers or whatever. A good glass man will come to your place and cut whatever you need. It's a simple flat panel put into a rubber gasket. The gasket is usually just cut to length and installed around the opening, then the flat glass is inserted into the glass channel of the rubber. Not complicated not rocket science, you will need to make the panel that holds the window stiff enough to do so. You will be surprized at how much weight youwill have.
   / Getting safety glass cut ?? #22
Yes any glass shop can cut lami for you. I replaced tons of it in dozers, backhoes,loaders ect.You can get it tinted too so its not that hot in the summer. Glass shops can even install the rubber to mount the glass in. Any shape any size ect a good glass guy can make it fit for you.
Rob
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
1991 Ford L9000  2,000 Gallon Water Truck (A59213)
1991 Ford L9000...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
DEL MORINO VICTOR FLAIL MULTCHING MOWER (A58216)
DEL MORINO VICTOR...
McFarlane 4025 Reel Disk (A59814)
McFarlane 4025...
