Give me some ideas on what trailer i need for kubota l3301
   / Give me some ideas on what trailer i need for kubota l3301 #1
MIke Castillo
Monkton, VT
Kubota L3301 HST
i really need a trailer to do several things. 1) Haul my new kubota L3301 FEL and an implement or two, to and from my home to my other property 4 hours away. 2) i need a general trailer to haul trash, pick up mulch, stone, etc....just regular home use. I currently do not have a large enough vehicle (toyota tacoma), but am looking at upgrading to a tundra in the near future. Any ideas on a trailer that would suit my needs?
Thanks for the help! Mike
   / Give me some ideas on what trailer i need for kubota l3301 #2
7K landscape or utility trailer, dual axle with ramps. Around here, 3 to 4 Grand. BTW, I have the same tractor, I FREAK'N LOVE IT.
   / Give me some ideas on what trailer i need for kubota l3301 #3
I wouldn't go any smaller than a 7x16 landscaper (what I have), though if you do get a landscaper, you will need ramps instead of a rear gate for the L3301. I used the rear gate for my B2920, but could tell it wasn't going to be strong enough for my L3200. That trailer runs $2200-2500 around here.
   / Give me some ideas on what trailer i need for kubota l3301 #4
Yep, a 7x16 car hauler-an 18' would be better. 7k would be good, 10k if you are going to get. Tundra with the big motor. Definitely get slide in ramps.
Will
   / Give me some ideas on what trailer i need for kubota l3301 #5
I have a 18' landscape 7000# trailer. Weighs 1400# empty leaving 5600# for stuff. Has rear pull out ramps that take all of 30 seconds to set up.
Chris
   / Give me some ideas on what trailer i need for kubota l3301 #6
If it was me I would go with a 20' 10k trailer. I'm guessing your tractor weighs about 3500 lbs if you have your tires filled, add a couple of attachments, say a brush hog and a box blade, and you could be up around 5000 lbs. A 7k would work but you'll be near it's limit while the 10k will have plenty of spare capacity. I say 20' (if you have the room to store it at your house) because it'll allow you to load an extra attachment on the trailer. That way you free up the bed of your truck, property that's 4 hours away is far enough so I would want to take everything needed in one shot.
For the other stuff listed a dump trailer would be ideal but they aren't cheap. Instead I would try to find a trailer with stake pockets so you could make sides. Or if you get a landscape trailer you could make sides that hang off the railings. I might even look into getting a steel deck vs wood. It would allow you to use the loader to scoop out gravel off of the deck without fear of catching the wooden planks.
   / Give me some ideas on what trailer i need for kubota l3301 #7
A 7k, tandem axel landscape trailer wood do it, but I too would go 10k and 20ft. I ran an 18ft trailer with my b series kubotas all over the place doing jobs and the whole time I wished I had a 20ft long one. Sometimes a 22ft. My old b series were smaller then your L, so...
Also, just my 2 cents worth, maybe give some thought to keeping your tacoma, and looking for a used 1 ton dump truck to tow all this. Would seem to solve all your needs and I bet you could get a used 1 ton dump for way less then a new tundra. They seem to show up on craigs list and I have seen decent ones at the 5k price area. Good luck and enjoy your kubota!
   / Give me some ideas on what trailer i need for kubota l3301 #8
My old B series with loader and 4' rotary mower completely filled up a 16' 7k trailer. Had plenty of margin for weight, but with the mower it was long.
This is a little bigger tractor, heavier, and would be pretty long with a 5' mower. Remember, you want room to balance the load, so you want a trailer longer than the overall length of your tractor.
I would get at least an 18', and probably a 20'. For a 20', consider a 10k trailer.
I never wished my 16' trailer was shorter, but a lot of times wished it was longer...
   / Give me some ideas on what trailer i need for kubota l3301 #9
^ This! If you have the space and will be getting the tow vehicle to accommodate it I would suggest a 20' as well. I have a 10k 20' with a toolbox on the deck and a 2' dovetail. Arguably, that gives me ~16' of flat deck which when I load my BX with FEL and brushog gives me enough room to adjust for balance with the mower hanging over the dovetail but does not leave space for additional implements unless I get creative.
The trailer is way more than required for my tractor, but gives me a very stable platform for options down the road. The point is lengthwise it is comfortable with my little tractor and a toolbox without being crammed or carrying too much tongue weight. You have a proportionately larger tractor. Best luck with the decision!
   / Give me some ideas on what trailer i need for kubota l3301 #10
Believe it or not, the OP's L3301 (and my L3200) are somewhat short/stubby for their size, and are not much longer than something like a B2620/2920. I seem to remember that the L actually has a shorter wheelbase than the new B2650. So based on my experience towing both a B2920 and L3200 on a 7x16, I think that is an acceptable "minimum" size. With both tractors, I had plenty of room to move fore/aft to balance tongue weight with tractor only. With a short rear implement (wood chipper, stuck out about 3.5-4') it was still barely enough. Any implement longer than that, however, whether a B or an L, I'd say a longer trailer is definitely needed.
And one caveat, of course -- when looking at longer trailers, be aware that many configurations have dovetails which reduces the usable deck length. An 18' with dovetail doesn't have any more usable deck length than a 16' flat trailer, and so on. That extra length is usable, however, for hanging long implements over the dovetail if they don't need support at the very rear. Just remember that if the weight needs to stay hanging off the 3-pt hitch (because the implement is airborne), it's impact on balance and tongue weight is happening through the tractor wheels (primarily the rear wheels) and won't be moving the tongue weight aft nearly as far as if the implement was resting on the deck. Then consider if the trailer has fixed ramps or gate that raise up, as they could potentially interfere with hanging an implement off the back. So there is a whole lot to this notion of length and balance, and a longer deck isn't the only factor.
If it were me and for some reason 16' was not conclusively long enough, I'd probably jump to 20' flatbed to really get an extra usable 4' of deck. An 18' flatbed isn't much bigger than 16', and an 18' dovetail isn't really any bigger in many scenarios.
Finally, other considerations like maneuverability, storage space, tow vehicle capacity, and general use come into play. I remember at the time when I bought my 7x16 landscaper, I was debating hard going up to 18' or 20' equipment trailer. They would have been better for towing my tractors, for sure. But they both added extra weight that ate up the margin of my (then) tow vehicle, they were going to be harder to store behind my barn, and they weren't going to be as good for other tasks like fetching materials, mulch, lumber, etc, where sides and a rear gate are nice to have. So I compromised on the 7x16, and it's been a good trailer so far. I towed my tractors almost every weekend for 2 years while we were building our new house, and have gotten dozens of loads of mulch, gravel, lumber, etc. For all those non-tractor uses, the smaller lighter trailer with sides and a rear gate was a better choice. It was "just enough" for my tractor towing needs but got the job done fine.
2015 Ford Taurus Sedan (A44572)
2015 Ford Taurus...
40ft 5 Dual Door Shipping Container (A44571)
40ft 5 Dual Door...
INOP/NON-RUNNING 2006 Ford F-450 Pickup Truck, VIN # 1FDXF46P76EA76573 (A44391)
INOP/NON-RUNNING...
Volvo EC330BLC Excavator (A44391)
Volvo EC330BLC...
Welding Trailer (A45336)
Welding Trailer...
2007 GMC C8500 Altec AM650 Material Handling Insulated Bucket Truck (A44571)
2007 GMC C8500...
