GL4 and GL5 gear lube and bronze gears and bushings
   / GL4 and GL5 gear lube and bronze gears and bushings #22
Another utf product..
   / GL4 and GL5 gear lube and bronze gears and bushings #23
It's the higher level of EP and Anti-wear required for GL-5 performance that generally make those oils aggressive to yellow metals. In actual fact the GL-4 performance tests have not been available for several decades but what many oil companies do is to simply take the GL-5 additive and halve the treatment level to make a 'GL-4'. The lower concentration will give an approximation of the claimed GL-4 performance but without being so aggressive in terms of yellow metal corrosion.
   / GL4 and GL5 gear lube and bronze gears and bushings #24
When I changed my front axle oil I used walmart supertec GL5 and the label said the formulation was yellow metal safe. Soundguy already mentioned this one.
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
2839A (A54757)
2839A (A54757)
2020 Brenner 450 Gallon Skid Mounted Vacuum Tank (A52377)
2020 Brenner 450...
2016 IZUZU NPRXD S/A BOX TRUCK (A52706)
2016 IZUZU NPRXD...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
