Glare Ice Solution
   / Glare Ice Solution #1
Wyobuckaroo
Platinum Member
NW BC CANADA
John Deere 2032R
Earlier this fall I got a Piranha tooth bar. There are 10,000 posts about them. About 60% of the reason I got it was to be sacrificial and not ware down the cutting edge on my FEL bucket moving snow on our long gravel drive. It works well moving snow AFTER you do some learning curve of how to set the working angle and remembering it is out in front of your usual bucket edge. It is easy to have it gouge the driveway until you learn to use it.
So now we have a good solid base of frozen ground and packed snow to work with for the rest of winter.. Problem is it went to glare ice on a bit warmer day a while back. A real broken hip type of dangerous.
With the tooth bar on the loader bucket, I tipped it at about a 45 degree angle and back drug it on the glare ice of packed snow on the driveway. It seemed to work well. It worked best to go 2 directions with this pattern at 90 degrees down and across the drive and yard.
Today I did this procedure again. This time I tipped the cutting edge about 60 or more degrees from flat. As I have a more solid base frozen down now this worked well. Again dragging both ways down the driveway and across the driveway making a checked pattern of grooves in the ice.
The secret to making this work is to not take too much weight off the front tractor wheels so you still have some steering control. Better to make multiple passes.
DO NOT, repeat DO NOT go fast. Take is slow and easy as a ridge in the ice or a low spot will make the tractor front end skate sideways. You don't want to be going fast if/when this happens.
Traction is not a problem as I have heavy duty V bar ladder chains on loaded turf tires.
I still plan next summer to build a clip on bucket attachment with more ice cutting edges than the 8 edges on the tooth bar. I'm thinking 24 - 25 or so edges 3/8 thick across the bucket front.
My 5 cents of experience.
   / Glare Ice Solution #2
I have one 150 foot section of my driveway where snow melts from a big field - runs down this section and makes a real skating rink. Add to this, its a fairly steep section coming out of the valley on my driveway. 37+ years of trying and I still can't keep this drainage off my driveway.
I've used just about everything - except salt. Pine needles, ancient pellets left over from my pellet stove, shredded pine cones, old composted lawn clippings, sawdust from my work shop. The best is if there is still a soft shoulder here or there on the driveway - I just might be able to scoop some sand/gravel.
When this section ices up its best not to play games on this slope. One could easily slide off the side and its a ten foot drop.
Sounds like you have figured a good solution. An icy driveway is the pits - I've fallen in this spot many times.
   / Glare Ice Solution #3
I use my box blade with the scarifiers down to achieve similar results with the glare ice on my gravel driveway. I may change the box blade's angle of attack by adjusting the top link or extend the scarifiers as needed.
Then come the wood ashes from the wood stove. Ugly looking, but effective.
I agree. I do not think falls are a good thing for anyone of any age.
   / Glare Ice Solution #4
I use a pair of stretch-on rubbers for boots that have steel teeth on the bottom. I'm not falling with these....they work great for gifts too. I also use sand on ice.
   / Glare Ice Solution #5
When we had a wood stove I tried ashes one year. Like jbrumberg said - effective but ugly. However - some slew footed individual managed to leave big nasty ash foot prints on our beige livingroom carpet. Not a winning day for the slew foot - me - or for my wife.
   / Glare Ice Solution #6
I had a large one way disk, maybe 5 or 6 disks, 30 or so inches for a 3ph. It was great at attacking the ice and making it walkable and driveable.
Unfortunately, I was using it for some earth work, a cotter pin came out of one end of the axle, and long story short, I broke a bearing housing and scrapped the whole thing.
   / Glare Ice Solution #7
Ice can be a real pain. I try to not let snow get packed down as it'll sooner or later rain on it then freeze. I'll use the rippers on my land plane and I've even used my tire chains (they have 3/8" spikes on them) by spinning the tires. What my plan to make is a 3pt hitch mounted drum roller with spikes on it. I've seen them used on loaders and with enough pressure on the spikes they will break up the ice. I just need to find time to make it and a source for the spikes (would like carbide so they last). I've even thought about making a PTO driven vibrator and a weight bucket so I could add pressure to get the results needed. But for now I have a large pile of sand and with just a little practice I can spread it out pretty easily with the loader.
   / Glare Ice Solution #8
Ice isn't the pain. The pain comes when your bones hit the ice!
   / Glare Ice Solution #9
"..... some slew footed individual managed to leave big nasty ash foot prints on our beige livingroom carpet. Not a winning day for the slew foot - me - or for my wife."- oosik I can relate. I need to learn how to levitate. I do not spread ashes near the entrances I use CaCl2 in those areas.
IT- I am sorry to read how your disk became high grade scrap metal.
   / Glare Ice Solution #10
I drag a thin layer of snow back onto the packed slick ice when needed. It gives some instant traction, it's clean, is usually available along the whole drive, and it freezes in place for good traction until we get a longer warm day when it melts with the ice. It sounds counter productive to scatter snow on top of an ice problem, but try it sometime. :thumbsup:
2012 John Deere 7230 (A47307)
2012 John Deere...
Skid Steer Trailer Hitch Plate (A46502)
Skid Steer Trailer...
Four 55 Gallon Drum Cradle with Wheels (A45336)
Four 55 Gallon...
2009 Peterbilt 384 T/A Day Cab Truck Tractor (A46683)
2009 Peterbilt 384...
Rears 500 Gal Orchard Sprayer (A47307)
Rears 500 Gal...
2006 JLG 2030ES 20ft Scissor Lift (A44571)
2006 JLG 2030ES...
