Glare Ice Solution
   / Glare Ice Solution #21
My dedicated snow plow is a '91 F-350. I leave it chained up year around and when it gets icy, I just go round and round several times and scratch up the ice.
   / Glare Ice Solution #22
I don't let ice happen, I lay down 100% straight salt and doing that, dries the asphalt so no water can freeze thaw and then re freeze. Slip and falls are not worth the risk.
   / Glare Ice Solution #23
Where I live, salt is ineffective below 0 degrees F.
   / Glare Ice Solution #24
Plus straight salt is expensive and if used on gravel makes mud and the brine is corrosive.
   / Glare Ice Solution #25
Salt here can be treated and I believe it's effective to -15. They call it Magic salt. May just be a local brand.. not sure. It typically adds 15.00 per ton to the cost
   / Glare Ice Solution #27
I think we began using calcium chloride and sand at our schools. The calcium chloride melted ice down to -25F. The sand just added some grip and lessened the amount of ice melt needed.
   / Glare Ice Solution #28
Out here I think they pre treat the roads with Mag chloride. .. may be calcium..but I think it's Mag .. it's a linguistic that the salt trucks spray from saddle tanks beside the sand hoppers. .. stuff is brutally corrosive..but the streets are not frozen.
   / Glare Ice Solution #29
Same here. Our vehicles are white come Spring due to all the road salts. Only saving grace is our low humidity in the winter.
   / Glare Ice Solution #30
I use a walk behind fertilizer spreader, nice one with pneumatic tires.
I 'locked' the differential and load it with crushed slag* sold as traction aid at local box store.**
2 bags seems to do me a winter at that is a mere $2-3/ bag.
I spread it fairly lightly as in reality not much is needed (I call it salt/pepper spreading)
I'll add that I have reasonably steep hills that demand a 4 x 4 vehicle.
*that 'slag' while a tad pricier outperforms any sand and even crushed 1/4 or 1/2 stone.
Most sands simply get washed away and hide under any snow while the crushed slag (and stone) remains proud for traction.
**One walk up and back pushing the modified seed spreader is all it takes after an ice or freezing rain event.
Another thing I do is drive back and forth with my CUT that is chained up with dual cross links that are studded.
That helps a whole lot and generally I can drive my KIA with the all wheel mode locked using manually selected D2.
From my front door I have 0 distance to accelerate to the hilly section so need everything on my side.
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
207281 (A52708)
207281 (A52708)
F-150 Running Boards (A57454)
F-150 Running...
2016 KENWORTH T680 TANDEM AXLE DAY CAB (A59575)
2016 KENWORTH T680...
