Glare Ice Solution
   / Glare Ice Solution #32
My neighbor is a masonry contractor and he gets salt/sand mix and I have a open shed at the end of my drive that he puts it in and I have a Herd spreader I load up after plowing and spread on his hill and my hill. He pays for the material and I spread it, good deal. P2100018.JPG Wish I had a better picture of it.
   / Glare Ice Solution #33
I gave up on forcefully removing ice as last year I ended up pulling a huge chunk of asphalt with it Now I just buy bags of sand from Home Depot and spread it. I also wear cleats when I go out to feed the ducks and chickens.
My intention is not to remove the ice, but to make it safe to walk on. A certain amount of ice along with frozen ground and gravel surface is an OK base to work from when blowing snow and such for the bulk of winter. But not acceptable when dangerous to walk on. The combination of the cross hatch pattern, salt, sand, ashes all help to make the surface more manageable. We also use boot cleats and ski poles for stability.
Funny thing kinda sorta. Years and years ago I was the "crash test dummy" as it were for my big brothers karate classes. I learned to "fall down" without being hurt. Or at least minimal hurt. There actually is an art to that. It has helped many times over the years.
What ever it takes to keep safe.
As we get older though, landing right isn't as easy as it used to be. Combine that with the ever increasing power of gravity and it can get a little tricky. I have a nice set of creepers for walking but that doesn't help the driveway, which turns slick when it rains (as it's supposed to do tomorrow) I am currently welding something up so that I can mount box blade scarifiers for ice. I was going to build it so that I could side it onto my pallet forks and have down pressure but decided that was another recipe for disaster about the time I start siding down a hill the way that I did last year. I want the biggest bite on the rear, to keep me going straight.
Same here. Our vehicles are white come Spring due to all the road salts. Only saving grace is our low humidity in the winter.
Vehicles are white, but the frame and brakelines turn brown- actually, more of a rust color.
   / Glare Ice Solution #34
I wonder how well a ratchet rake would work for scoring ice...
   / Glare Ice Solution #35
I've been wondering how my disc harrow would work, but am afraid that I would break it.
   / Glare Ice Solution #36
The V-Bar crosslinks on my tire chains do a good job of scratching and scoring the ice glaze. After that, the colder it gets the less slick the ice becomes. Incredible traction -20 and colder.
Yes... I have thought of that, but of all the posts about that tool, I've never seen anything said about use on ice.
No reason it would not help a bad situation, as anything is better than a dangerous surface.
What I am in the process of day dreaming to develop for a clip on bucket attachment may incorporate some of the features of a Ratchet Rake.
Time will tell by when I get around to building something and what materials are available at that time.
   / Glare Ice Solution #38
I would think some hard surfacing rod "nipples" on a piece of flat barstock that can be bolted to either the bucket or any rear implement would certainly work to break the surface glaze. Cheap too.
1994 HEIL BULK TANK TRAILER (A59575)
1994 HEIL BULK...
2021 Keystone RV Cougar Trailer, VIN # 4YDT29B25MV508190 (A57453)
2021 Keystone RV...
2019 Deere 35G (A53317)
2019 Deere 35G...
16ft Enclosed Trailer (A57453)
16ft Enclosed...
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56436)
2016 Chevy...
CHANDLER 500 BBL FRAC TANK (A58214)
CHANDLER 500 BBL...
