Glow Plugs MANUAL TYPE KIOTI LB 2202
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #21
Your next step would be to isolate each glow plug by removing the bar or wires that conects them. You can use your test light as a cotinuity tester by hooking the ground clamp to the (+) post of the battery and touch the prob end to the top post of each glow plug; if it lights up it is most likely good. BUT on rare ocations a glow plug will burn out and short to ground. When this happens it usualy burns out the coil indicator. I hope I didn't confuse you.Dan
Do i have to turn the switch back like iam trying to heat them up or just leave off by doing it the way u said.
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #23
Just leve the key alone. Do the test on each glow plug I would gess you have one or more bad plugs.
I will test tomorrow afternoon and get back with u thank for all your help and everybody else to.
   / Glow Plugs MANUAL TYPE KIOTI LB 2202 #25
part # E5500-65512 for the glow plugs
part# 15401-65561 for the "wire" that connects the glow plugs to each other.
We are gonna get this machine starting for this gentleman---------yep-yep-yep--------
virgil
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
City of Tampa (1202)**Title MUST be transferred into buyer's name INCLUDING DEALERS. All titles (A51692)
City of Tampa...
P.T Farm Wagon (A50121)
P.T Farm Wagon...
2003 Ottawa Spotter Truck (A50120)
2003 Ottawa...
2016 John Deere 6130M (A50120)
2016 John Deere...
2021 John Deere 6175M (A50120)
2021 John Deere...
