Glueing Magnets to Aluminum Strip
   / Glueing Magnets to Aluminum Strip #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, its not welding but it is for welding. I am making some plasma straightedges and was using epoxy to glue the magnets to a strip of aluminum. But I have already had one fall of. Any suggestions?
   / Glueing Magnets to Aluminum Strip #3
No exposure to high heat? Contact cement.
   / Glueing Magnets to Aluminum Strip #5
Yeah, you can get small donut magnets with a countersunk hole in them for mounting.
   / Glueing Magnets to Aluminum Strip #6
The aluminum should be roughed up (scratched) where the magnet is to be glued...you might try contact cement...coat both the magnet and the (scratched) aluminum and allow it to dry then press them together...
   / Glueing Magnets to Aluminum Strip #10
Mounting magnets from kj magnetics.
Or try silicone adhesive. I like GE silicone II caulking, but I think Elmers Stix All is the same thing in a small tube. I'm sure there are others too.
2016 PETERBILT 579 TANDEM AXLE MID ROOF SLEEPER TRUCK (A54607)
2016 PETERBILT 579...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A55788)
2002 Ford F-250...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
Scissor Lift (A55851)
