SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,284
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
The loader takes precedence over the remotes so it could still work fine with a remote on. Just that when not using the loader the remote would be flowing thru an active circuit or a relief, using one [up to several] HP w/o you knowing it.Larry,
1st in high range is 9th gear. 4 gears and 3 ranges....low, middle, and high =12 speed. I can't see how hyd. flow would make going, slow. Was hauling dirt from the pond spoils pile and the loader worked fine while moving.
KTWO,
I will try shifting between 2 & 4WD next chance I get.
Bob77064,
Been hauling dirt......it's not an air pressure issue. But maybe I need to let the summer air out and put in winter air:laughing:.
hugs, Brandi
... I understand how you mean 7th gear. Looked at by ratio tho, on mine at least, 1st hi range is a "lower" gear.
larry
