Spiveyman
Platinum Member
flusher said:Let the engine run for 15-20 minutes at fast idle. Check the radiator hoses (top should be hot, bottom should be warm).
With only 60 hours on the engine, the exhaust output should be nearly invisible (black smoke = probably OK, lotsa white smoke= possible water leak into the combustion chambers, blue smoke=burning oil).
Engage the pto and run the engine rpm up to the pto mark on the tach. Listen for suspicious noises.
Check the 3pt controls to be sure that the lift arms are working OK. Best if these pto/3pt checks are done with a mower on the tractor, but that usually isn't possible in this kind of deal.
Flusher, Thanks for these hints. I pretty much rolled the dice on my tractor and got lucky, but I appreciate this type of practical advice in looking for obvious things wrong with a tractor. I'm not that mechanically inclined so these types of hints really help. I saw "blue smoke" posted elsewhere and wondered what the colors indicate. Luckily on my 1991 Ford all I see is a tad of black smoke when I give her lot's of fuel.
dieselfuelonly, have you tried looking on tractorhouse.com They have a pretty good selection usually.
