RoyJackson
Rest in Peace
- Joined
- Nov 17, 2001
- Messages
- 23,144
- Location
- Bethel, Vermont
- Tractor
- John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
dieselfuelonly said:Now is that something that the tractor has or something that I can buy?
Sorry I'm new to this.
You can buy an over running clutch at a tractor supply store. What this clutch does is a one way power transmission device. The tractor's PTO can drive the implement, but the implement's momentum cannot be transmited back to the tractor. Otherwise, that momentum can propel the tractor through the (tractor) transmission even if the clutch is depressed. When you would expect to be stopping, the tractor would continue motion in the direction the tractor was heading (forward or reverse) before clutching. Simply, you won't stop when you expect to be stopping.
Can you add a dual stage clutch...probably, if you want to spend the $1500-$2500 it would cost (it's more then just replacing the clutch pack...there are several other components that would require replacement as well. This assumes these parts are even available.
Y'know, dieselfuelonly...I'm not sure you're making a good choice with this Yanmar. I'm not saying it's a bad tractor, but it's probably not a good choice for a novice tractor operator. Perhaps you should reconsider this. Only you know your capabilities, so it's your decision.
To help you understand the tractor you're considering, I suggest you read over this info provided on Yanmar Tractor Parts, Sales, Service, and Delivery.. Seems to have a lot of info available right on the site as well as a source for manuals. Remember, any repair work or maintenance would be done by you (if you're OK with turning a wwrench) or come out of your pocket.
THINK!!!
