The problem I see with hydros. In the old days the hydros were sized for the horsepower, today they are not. example: The Ford 1320 had a hydro sized for all 20hp the engine could deliver. Today the same frame, tranny etc has a 30hp engine mounted to it. Mowing etc the combination works great but put it under load on a plow and it is a different story. The New Holland tractor we had had two coolers at $1500. apiece before the warrenty was off. Traded the tractor the same week the warrenty expired.
Another example: Steiner tractors use a Sundstrand series 15 hydro system. Sized for 18hp max at 3600rpm. On a test tractor I saw 10,000psi with a 23hp Onan engine. Sundstrand says max psi is 5,000psi. Now they put 32hp diesels running at lower rpms which requires even higher pressures as fewer gallons per minute have to take the work. On a lawn mower it may be ok but put that on a load, pop the relief valves and watch the temps soar! Dumping 20gpm over a 2000psi relief is nearly equivalent to a 35,000btu heater stuck to the system.
If you want a lawn tractor by all means buy a HST. If you want it as a farm tractor, best buy a geared tractor.
