Good morning!!!!
   / Good morning!!!! #117,001
By the time I finished a 3rd cup of coffee, the sky was promising. Still too wet to finish area from yesterday but I ventured to other side of the house and got another 3plus acres with the flail. One of my test criteria, if the tires glisten as I mow it is wet. Still have another 2-3 acres - tomorrow?
   / Good morning!!!! #117,002
Kyle....most likely gonna go on a long ride on the Triumph. But, now that the Gold Star dynamo is no longer misbehaving, it is gonna get some miles too.
Did not make as much progress on the trailer as I wanted, but seem to have had the light come on for the front cabinets. Actually, a number of things seem to have come into focus on that project.
   / Good morning!!!! #117,004
I mowed along the road, the grass was tall and heavy. Then son mowed.
My dads riding mower that I bought him back around 2004 isn’t running too well. One of the guys that hunts on him was mowing with it and called my sister and told her it broke. Then dad took it and mowed with it yesterday and said it was just burning some oil.
So I decided I need to fix the transmission in my husqvarna and take it to him. $500 for hydro pump rebuilt kit or $1000 for a complete transmission that I don’t have to tear down and mess with. Pushed the mower out of barn, battery was dead. Put air in flat front tire. Charged battery, sprayed little carb cleaner in air filter, and it started right up. I even mowed with it. Transmission works until it warms up, then won’t pull a slight hill. I’ve had to use a little carb cleaner to start it since about the 2nd or 3rd year of buying it.
Wife bought a bushel of green beans today. We just got first batch in the canner. Should be able to get around 21 qts from the bushel.
While waiting for battery to charge I mixed more roundup and sprayed.
   / Good morning!!!! #117,005
Deep creep is a penetrating oil.
Not looking for a peeing match but if you look at Seafoam's web site they have a product named Deep Creep but it may be spelled Kreep,I don't remember. nI do know that it has worked very well several times for me.
   / Good morning!!!! #117,006
I looked, that’s why I responded. Sea foam makes a spray, but deep creep is a penetrating oil.
   / Good morning!!!! #117,007
Good evening all. 79F for the start, partly cloudy, moderate wind. Wind 15-21, partly cloudy day, high temp 99F feels like 107F. Meeting this morning, bike ride, was going to shop but family circus interrupted, did get nap in and grilled brats for dinner tonight.
Covid update: Cooke 248 confirmed cases, 0 active cases, Montague 77 confirmed cases, 1 active cases, Grayson 1169 confirmed cases, 41 active cases
RS Sorry about the Menard's troubles, bet that made for a "fun" day
Roy that is a 30F swing
Drew hope the Dr "visits" went well. Understand about local food issues, not much in way of local restaurants here, period
Eric remember Battleship, storms don't find many Texans during summer. So sheep are get stuck artists as well as escape artists?
Ron good luck with driver license renewal, never fun.
Billy we are almost as dry as Rick (irrigation helps) good you got a hike in. Coco get to go?
Rich refresh my memory what are you doing to trailer?
Don good luck with weed eater, on mine the choke is my friend.
RNG Firetruck in place, yeah! Nice the network upgrades are working out for you. More room with safe gone ( or will be)
Jim thanks for info on Seafoam Creep
Bird glad you are hanging in there with summer heat, hard for me to put in more than half a day with the heat.
Lou cab a/c is cheating :)
David sorry about rain, enjoy Dinner meeting
Don I thought the Chinese could copy better than that :(
Ron nice cabinet, glad you got driver license renewed
Randy, too hot for me to stay out.
Rick getting the files and other stuff back in place is always the issue
David glad you got some mowing in.
prayers for all especially Drew, Jay/Peg, Kyle's daughter, Mike, David (Moss), Country
Stay safe and healthy you all.
   / Good morning!!!! #117,008
73F and partly cloudy @ 22:00.
Started day with adding more Plastic Wood to knot hole in siding. Eventually got that completed (front and rear) ... just needs a little sanding at this point and should be good to go.
Then unloaded pallet of block from van, took loader off Kubota, greased pto shaft on MMM, hooked it up and did a couple of passes on the front to set the pattern for today's mowing and check for any vibrations on the new installed blades. After that I got The Woman, who had been weeding the blueberry bed, started on the mowing.
While she was doing that I got out the Stihl HT 101 pole saw and cut the oak tree branches off the electric service lines coming from the transformer to the house. Should be able to tie a rope on the tree tomorrow and put some tension on it with the Kubota and cut and drop it.
Then I headed over to the Depot to pick up six 1/4 x 6" Spax star head bolts to attach the additional 4 x 4's to the bottom of the auger rack. Hope to get that completed tomorrow.
When I got back we took her car down to the repair shop to drop it off to have the front wheel bearing replaced.
When we got back from that I worked a little more on pulling the cut branches from the oak out of the rhododendron, then started removing the top of the auger stand from the base. She continued with the mowing and got the entire front mowed ... :thumbsup:
Then after dinner I headed back out to mow down here around the house.
Got one pass done and noticed that the rubber on one of the gauge wheels had torn off the steel sleeve it was bonded to. Not really happy about that considering they are around $100 a pop ... but on the other hand, it's the first one I've had to replace in 2231.9 hours ... hopefully the dealer will have them in stock. If they do I'll probably just go ahead and get two and replace both front wheels ... that way I'll have one old one as a spare so if one of the rear wheels goes **** up while mowing I'll be able to replace it and hopefully finish.
Chances of rain seem to have mostly evaporated until at least Saturday ... last rain we got greened things up but I suspect it's going to start looking dry again in fairly short order.
Hope everyone had a great day ... :thumbsup:
   / Good morning!!!! #117,009
2020-08-12, 0333
72 right now...high in the mid-80's today.
   / Good morning!!!! #117,010
71 high of 90 today storms possible later flood watches posted close by
Prayers for Drew, Jay and wife, Kyles daughter, MFW, riptides, all others our Country
2008 CATERPILLAR 272C SKID STEER (A52705)
2008 CATERPILLAR...
2011 Volvo S40 T5 Sedan (A55758)
2011 Volvo S40 T5...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2015 Nissan Versa Hatchback Sedan (A55758)
2015 Nissan Versa...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
