Good morning!!!!
   / Good morning!!!! #213,131
Second this ^^^
Also does it have a bladder and has the pre-charge been checked lately ?
That should be done at least once per year.
Frequent start/stop cycles are hard on the pump (aka "short cycling")
good things good minds think alike
I complained about the pressure tank my first year here, plumber came out and replaced with a whole new unit.
So not the bladder though I could check the charge
pump makes enough noise sounds like it will cough a bearing, no idea how old it is.
finished fussing with rv and ready to take it to dealer tomorrow morning for an inspection and trade in value.
I'm quite sure I will bring it home with no solution that doesn't involve a financial beating.
would rather keep it another year. Now that my old friend has his first rv, means we can meet up places.
but a lot of maintenance if I want to keep it nice. Travel trailer would be a lot easier.
dealer admitted motor home pricing had tanked.
going to get pretty cold tonight
highlight of my day was having to crawl through the window in the garage, again, for the third time..., since the gfi tripped and the stupid garage door battery backup failed again. I need to fit a bigger battery in it, have a spare, maybe wire them in parallel. I'm too old to be crawling through windows onto top of plastic table rated for 300 pounds, that already had a bunch on it, that sits under the window. Have no idea why gfi trips, don't think it's the rv hooked up. I ran the generator on that today and glad I did, took a while to pump gas until it started.
am looking forward to a quiet night with a good book.
   / Good morning!!!! #213,133
Trying not to get my hopes up too high but there is a possibility that I might be getting close to hitting pay dirt on the frac'ing.
Was making calls to all the firms listed in the PA database for western PA and noticed there was a firm listed with a 330 area code.
Looked them up and found out they are located just down the road in Canal Fulton (6 miles south)
They're more of an environmental services firm - engineering, testing, UST's, brownfield remediation and the like - that was founded by some local geologists ... so I was pretty sure that they wouldn't be a provider but figured that maybe being in a somewhat-related field someone there might know of someone in the area that did water well frac'ing.
As luck would have it my call got routed to a fellow who had to have the well frac'ed at the family home out on River Styx Road in Seville in order to sell it.
Said they had a real hard time finding anyone local to do it but had great water and well productivity after it was done.
He didn't have the number handy in his phone but made a call to Grandma who is now on the case, going through old paperwork to try and come up with a name and number for the firm that did it.
Here's hoping ... 🤞
Sounds as if you are on to something. 🤞
There are chemicals to dissolve up iron, and if you suspect iron bacteria, I'd go heavy on the in well chlorination when you are done. That might be a maintenance item for your well going forward. I have heard of down well ozonation systems, but I have never used one as there's no small amount of maintenance on them, both the ozone generator and the special oil free compressors needed to bubble the ozone to the bottom of the well.
If you have a tire gauge, you can check the bladder pressure pretty easily. Just turn the pump off, and open a faucet to drain the system pressure to close to zero.
Ouch, climbing through the window sounds like something I would want to avoid. I guess it makes for a good story, and I'm impressed that you can do it! So thanks for sharing.
Any chance of a different breaker, or circuit to power the opener. If not, I would probably put a battery down at table level, disable the charger in the opener, and a real battery charger on the new battery. My opener back up battery replacement is always more futzing around way up in the air than I think is prudent, at least around here. Most of the time when I am up a ladder around here, I get to a point where I am thinking "now would not be a good time for an earthquake!"
All the best,
Peter
   / Good morning!!!! #213,136
First off, I wouldn’t write-off it being the bladder. Perhaps not likely but not impossible (manufacturing defect, etc)
Secondly, if the charge hasn’t been checked since it was installed, I’d definitely do that.
Could be getting old and near the end of its life.
   / Good morning!!!! #213,138
Good (Friday) morning. Overnight Low of 6C and it's presently 18.5C, mostly sunny and calm.
I'm very disappointed with the BOM who have revamped their website = I can't find anything!!!😡🤬
Apparently I'm not the only one 'ticked off' with the "New and Improved" BOM website as it was on the national news. We Ain't Happy.(n) Their response is, "You'll get used to it." <grumble>
Yesterday, my sore throat 'held off' enough that my dental and medical review appointments went off without a hitch. It's still present but at least I'm not stuffed-up or constantly coughing, which is good for sleeping at night... still, I let my Minister know that I may not be at Church on Sunday (I'm scheduled to 'lead').
I do need to go to the PO for a couple of deliveries. Other than that, I'll just concentrate on getting through this rare [for me] affliction.😐
   / Good morning!!!! #213,139
Back into the basement for further adventures in plumbing this afternoon.
Happy to report the seep on the cold water side of the water heater has stopped as I suspected it would ... (y)
Got a call back from a driller in western PA up around Meadville. Nice guy, spent about 1/2 hour on the phone talking to him. Doesn't do frac'ing or know of anyone that does. Nonetheless it was a productive conversation, got some idea of the variation of strata he works in where he's at (mostly shale) and the variability. Also happened to mention that he doesn't hold a license for the State of Ohio ... something I overlooked when I started looking for frac'ers in PA.
Started disassembling the plumbing that went into the softener, managed to unscrew housing on the unknown mystery device which contains a consumable cake which is supposed to prevent scale build up in the pipes.
Once I had it off I found a label on the backside announcing it's a ScalTrol:
Best Filter for Hard Water: Purify Your Water Instantly | Scaltrol
Interesting concept/system - from the FAQ on their website:
To counteract mineral build-up, the Scaltrol system’s patented head dispenses a measured amount of the Scaltrol proprietary compound (polyphosphate) which deposits a microscopic film to all surfaces. The mineral molecules, which have a positive charge, are then attracted to – and held in suspension by – the negative charge of the polyphosphate, which acts as a sequestrant. Since the mineral molecules are no longer able to bind together, scale cannot form.
The compound is safe and certified under NSF Standard 60. With the Scaltrol system, there are no moving parts and no costly circuitry.
Might partially account for why there is so little buildup in the pipes.
After that I went on to trying to unscrew the housing on the pleated filter. Not much luck with that, really tight.
It uses a plastic wrench that fits over the housing. Wrench is fairly flimsy and I have broken them before by torquing on them too much.
Time for Round 2.
   / Good morning!!!! #213,140
Time for Round 2.
Polyphosphate does wonders to keep calcium and magnesium from precipitating. Often it is used in water polishing applications and for secondary RO on the reject from an initial RO membrane to increase the yield.
My RO has a unique flimsy plastic wrench that I have broken a couple of before I switched to using a strap wrench with a longer metal drive.
Good luck on finding a fracker.
All the best, Peter
2011 New Holland B95B Cab MFWD Loader Backhoe (A55314)
2011 New Holland...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A53422)
2015 Ford F-450...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2014 Walker Compactor (A55787)
2014 Walker...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
