Goodbye Kubota, hello EarthForce
Status
Not open for further replies.
   / Goodbye Kubota, hello EarthForce #271
Re: More EF-5 info, pictures
The Brush Brute pic didn't post, but the rest did. Thanks. The switch hitch looks like something I've seen before, without the receiver tube(freedom hitch, maybe?). Again, thanks for the picks.
<font color=green> MossRoad </font color=green>
This picture shows the 84" grading rake from York. The black thing you see facing you is a removeable end plate for the drop down grading blade. The gauge wheels are adjustable in height by means of the little handle you see sticking out of the top of the wheel support tube. Total weight of the whole assembly is 947 pounds.
Wedged up against the front of the rake is the 30" McMillen tree auger.
MarkC
Ooops. Here's the pic of the Brush Brute...
MarkC
   / Goodbye Kubota, hello EarthForce #274
With all the power of your new Earth Force don't you need a sig that demonstrates at least one of its considerable capabilities? /w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
Mike - Cool! /w3tcompact/icons/cool.gif I had no idea you were a graphics artist...
MarkC
   / Goodbye Kubota, hello EarthForce #276
Bird's inclination that there would be a combination of 2 or more factors sounds right. Theoretically there might be another factor involved, traction or the lack of traction on the rear wheels. Obviously the lack of traction would never be an issue with a machine belonging to Mark but it might be fun to think about the physics involved.
What I am picturing is -- if there is enough power and the rear wheels don't turn due to perfect traction, the tractor will turn around the wheels raising the front off the ground. If there is not enough traction then the wheels turn instead of the tractor. For those of us up north we get to experience this during the snow removal season. Using FEL float in snow does not cause the front wheels to come off the ground but rather wheels just spin. Of course like Bird said the physics involved in the angle between the boom and the pivot point on the tractor (influenced by the distance from the ground and the length of the boom) will dramatically affect how much power must be applied before the wheels lift.
Now that I've thought about this "out loud" it seems that the biggest factor involved in Mark's EF wheels not coming off the ground is probably the front end weight (since we already know that traction is not a problem, or won't be as soon as the Michelin's arrive...). Just my two cents ... which ain't nothin' compared to the EF /w3tcompact/icons/smile.gif
DaveV
   / Goodbye Kubota, hello EarthForce #277
WOW! Stay out of that thing's way. Looks like it will do a great job on brush and saplings.
DaveV - Those sound like very good points to me. Obviously, there's no way the EF-5 is getting as much traction from those rear tires as the L4310 was getting with 19.5" wide Michelins when the L4310 was similarly loaded, but the only time the L4310 was similarly loaded was when the Bradco 609 backhoe was attached, which wasn't really very often, especially not when I was primarily doing loader work.
So, from a practical standpoint, since traction is affected mostly by tires and weight (discounting surface variables, of course) I may be getting close to the same amount of traction with the EF-5, on average, since the L4310 rear tire loading wasn't nearly as high when the backhoe wasn't attached, which was most of the time - and the EF-5 always has the backhoe on it. But, there's still no doubt about it: the EF-5 needs Michelin XM27's on it. Better is better, usually.
MarkC
   / Goodbye Kubota, hello EarthForce #279
How much did they get you for the forks?
bgott - $850.
MarkC
Status
UNUSED FUTURE FT-ECA63 ARTICULATING BRUSH CUTTER (A57193)
UNUSED FUTURE...
Honda Pioneer SXS700 4X4 Utility Cart (A53424)
Honda Pioneer...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2008 Ford Escape XLS SUV (A55853)
2008 Ford Escape...
