Goodbye Kubota, hello EarthForce
Status
Not open for further replies.
   / Goodbye Kubota, hello EarthForce #281
Re: More EF-5 info, pictures
Mark, I'm curious about the gauge wheels on the rake. The way they are mounted, in front of the rake and will be riding on the ungraded area. Hum wonder can they be flipped around to the rear of the rake. So the wheels will be riding on the graded part. This is what has me thinking how well all of these are going to work.
A friend of mine has a ASV posi track and really likes having the rotary cutter out front. I have never run it with it on there so I can't say. But have used it with the front end loader and it can move some dirt. Legal for the amish in this area to own so alot of them are popping up around here.
That picture of the pallet forks man those things look tough. Nice. As well as that rotary cutter, looks bullet proof. As for the brush brute it's already been said on this forum how tough they are. But it got me to thinking of another post that you made awhile back about getting ahold of the company. NO one there --- why cuz their moose hunting. I still laugh when I think about that one. I made a similar set up of the brush brute for the three point and really like it. Have to convert to the bucket to put down pressure on it, making it easier to clean. Can get alittle down pressure using the hydraulic top link but thats alot of times isn't enough.
I've got a couple of questions on the 4310 that I'm hoping you can answer as well. But that can wait a couple days. Cuz I know your busy playing with your new toys./w3tcompact/icons/smile.gif
Don't know if it's the pic's that does it or what. I tried the 1024x768 and it made it fit on the page but print and all was real small. Right now I've got it at 800 x 600 and the header at the top of the page tractor by net is fine but the thread itself is wider than the screen. Oh well.
Gordon
Gordon - I've been wondering about the gauge wheels running on an ungraded surface, too. I'll have to find out from experience, I guess. I did ask half a dozen folks who use this kind of implement, and they all claimed it works fine that way. All the skid steer implements work that way, even the laser operated stuff, so it must work ok. In answer to your question, though, you can turn the rake around and back-drag with it, which allows the gauge wheels to roll on the surface after it's been graded.
One of the enhancements I've been considering is a hydraulic gauge wheel that mounts to the cross-tube of the loader. That way, I'd have a gauge wheel that rolls on the graded surface that would work with any implement. It won't be easy to do, though, I suspect.
My neighbor rented an ASV with an Ammbusher on it about 2 weeks after I ordered mine. It was a 5' model, instead of a 6' one, but it would sure cut the brush...
One of the things I didn't particularly like about the pallet forks I had for the L4310 was that the kind that hooks on the bucket is hard to get out from under stuff if you don't chain or strap the bottoms to the bucket, which sort of removes most of the advantage of hooking them onto the bucket. With these, they're not only anchored at the bottom, but they lock into position side to side, have a good guard to keep stuff from falling back on your grill, and seem to be plenty heavy duty. They're rated for 5,000 pounds, but a customers I talked to at a dealer I visited told me he's used the same set on a big Cat TLB to lift well over 5,000 pounds with no problems, so I don't think I'll have to worry about them.
I can see where down pressure would be very handy to have with the Brush Brute, or a similar device. I don't see any way you hurt that Brush Brute, though - it's solid as a rock. But what would you expect of someone who closes up shop for several weeks to go moose hunting? /w3tcompact/icons/laugh.gif
As for the L4310 questions, ask away any time you like. I don't play with the toys at night anyway. /w3tcompact/icons/wink.gif
MarkC
   / Goodbye Kubota, hello EarthForce #283
Mark, how does the material caught in the teeth of the brush brute get ejected? Is there a mechanical means or do you scrape it off with the combination of reverse drag method? Also, do you grade with the York rake as in leveling the loosened material be it crushed rock or dirt? Thanks, Rat...
   / Goodbye Kubota, hello EarthForce #286
John, John, John, lets not stretch the truth, your article says and I quote "Jay Maners, owner of Taylor Rental in Mount Vernon, OH, a midsize rental company". Its hard to be the one to have to correct you. Rat...
P.S. kidding of course, thanks as usual for the great info but it does make me wonder just what it is you do for a living. I think of you as a professional tractor information getter.
   / Goodbye Kubota, hello EarthForce #287
<font color=blue>...think of you as a professional tractor information getter...</font color=blue>
Rat.... Shhhhhhhhhh.../w3tcompact/icons/wink.gif
   / Goodbye Kubota, hello EarthForce #288
Rat...
Wait til Muhammad gets my invoice.... /w3tcompact/icons/shocked.gif
Rat - With the Brush Brute, you back-drag to scrape the stuff out of it.
The York Rake can be used to grade with the tines or the blade. I haven't tried grading roads with the tines yet, but I'm anxious to. The product known as the FrontRunner is specifically designed to work that way - in fact it doesn't have a blade option. That's why I went with the York model, even though the FrontRunner has a bit larger tines. The advantage of grading with tines, instead of a blade supposedly is that you can work much faster, due to the forgiveness of the tines. Also, the tines supposedly don't gum up with debris, like leaves and pine needles, like a blade will. I'll report how it really works soon.
Of course, the rake can also be used for traditional rake uses, such as roots, debris, etc. so that, combined with the drop down blade, makes it a lot more versatile attachment, I hope.
MarkC
John - Nice links - thanks! I think the EarthForce machines are the most powerful machines in their class, easily. Of course, some might say that's a bit redundant, since there's not much in their class... As I said in a previous post, some of the full-size TLB dealers are finding that their customers are switching to EarthForce mini-TLB's, so that tells you something. One guy I talked to told of somebody he watched needing to put a pallet with well over 5,000 pounds of stuff on it on an 18-wheeler flatbed, but the forklift was busted - so he put a set of forks on an EF-4, went over to and tried to lift it, but the rear end came up off the ground. Undeterred, he backed over to a big rockbreaker, picked it up with the backhoe, went back over to the pallet, lifted it off the ground, moved it over to the flatbed and set it down, then went on his merry way. Now, I certainly don't know anybody else who would abuse a machine that way - do you? /w3tcompact/icons/smile.gif
MarkC
Status
2021 Kubota SVL75-2 Track Loader (A55314)
2021 Kubota...
King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
King Kutter TG72...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2013 International WorkStar 7400 Altec AM650 50ft Material Handling Insulated Bucket Truck (A55852)
2013 International...
1984 Gleaner A630 Corn Head (Deutz-Allis branded) (A57024)
1984 Gleaner A630...
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
