Gooseneck, 5th Wheel, or Bumper pull?
   / Gooseneck, 5th Wheel, or Bumper pull? #81
I don't like going 9 miles with a 10k bumper pull.
Is it just me, or does anyone else feel like they get whiplash from doing that?
   / Gooseneck, 5th Wheel, or Bumper pull? #82
It must just be you... :D
I took my tractor, and son to my parents on Friday. My son has been mowing my parents almost 8 acres this weekend. I estimate I was sitting at 6500lbs trailer/tractor. And yes, it jerked around.
My previously mentioned 5th wheel is only 1000lbs heavier; it is 27', has no slides. It is 7500lbs maxed out. It pulls like a dream, it is so smooth.
   / Gooseneck, 5th Wheel, or Bumper pull? #83
AKfish;1965414 If you're hauling 10 said:
I've put well over 45,000 miles pulling my 12,500 lb GVW PJ Flatbed Cargo Trailer attached to my Reese P/N 45008 Class-V Tow Beast Receiver Hitch with a 2-1/2" Square Receiver, cross-country most of the time fully loaded in the last 4 years from sea level to over 10,000' on major highways to dirt and gravel county roads and I don't experience all that jerking and bucking. Of all my 4 trailers that I presently own my 12,500 lb GVW PJ Flatbed Cargo Trailer, properly loaded, is one of the best tag-alongs that I've ever owned. And yes, I've owned and pulled GN, 5th Wheel, and Rear Hitch in my over 55 years of licensed driving.
To each his own!
Jim
   / Gooseneck, 5th Wheel, or Bumper pull? #84
When I traded trucks I didn't want two hitches in the bed. I installed the B&W flip over ball then I changed the hitch on the camper to a Goose Neck. It is a little tougher to hook up but I can tell no difference on how it tows. I t would be nice if the camper had more weight on the nose but I have enough truck for either trailer.
Dan
   / Gooseneck, 5th Wheel, or Bumper pull? #85
To each his own!
Jim
Jim - come on up North... if you know anything about frost-heaves and Permafrost you'll have a REAL experience in buckin' and jerkin'!!
Maybe another distinction - I've never owned a trailer LESS than 14,000 GVW. Current gooseneck is 15,700 GVW. So, when I travel from Alaska for another load; it's generally right at the maximum GCW for my truck - 22,000lbs. My DuraMax is just over 7,000lbs.
The bumper pull was like a giant tail shakin' a little dog!
AKfish
AKfish
   / Gooseneck, 5th Wheel, or Bumper pull? #86
AKfish
I'm very familiar with frost-heaves and a little with Permafrost. They will jerk and buck an 18 wheeler! I'm surprised that your GN doesn't jerk and buck with them! You are really getting your monies worth from your DuraMax.
Take care,
Jim
   / Gooseneck, 5th Wheel, or Bumper pull? #87
My one and only experience with a 5th wheel was not plesant. It was a 36' camper weight 14,000# being pulled with a 2007 Dmax 3500. I believe the issue with campers is the position of the axles but the thing teetered a lot and made the truck feel as if it were riding waves.
The 25' 25,000# GN I had and pulled behind my 1999 F-350 PowerStroke did much better. I think the truck was sprung heavier but the real difference was the axle placement on the trailer. On the GN they were 80% or more toward the rear.
I currently have a bumper pull and do not think I will ever go back. To each his own.
Chris
You didn't have enough pin weight.
   / Gooseneck, 5th Wheel, or Bumper pull? #88
Maybe. I do remember the truck was maxed out. I ran it across the scales and it was at 9,700# with me in it. The max GVWR is 9,900# on a 3500 Dmax so there was not much room to work with. Anyway it did not ride as well as I expected.
Chris
   / Gooseneck, 5th Wheel, or Bumper pull? #89
Chris
3500 at only 9900#? I assume it was SRW. Sad looking at the new specs as they are only rated at 16K GCWR.:( Even in the dually. Nearly 3 ton less than the 2001s-2004s.
   / Gooseneck, 5th Wheel, or Bumper pull? #90
Yes, it was in my neighbors 07 Classic 3500 SRW Dmax that he has so many issues with.
Chris
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2014 PETERBILT 579 (A58214)
2014 PETERBILT 579...
SHOPBUILT T/A BUMPER PULL TRAILER (A52708)
SHOPBUILT T/A...
2024 LandHonor PHA-16-2C Three Point Hitch Adapter Skid Steer Attachment (A56857)
2024 LandHonor...
2012 FORD F-550 SUPER DUTY (A58214)
2012 FORD F-550...
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
