Got a new Duromax XP10000EH Generator, propane question
   / Got a new Duromax XP10000EH Generator, propane question #41
Usually a high pitched whine is the starter not
fully engaging,,,just a thought.
   / Got a new Duromax XP10000EH Generator, propane question #43
How long is your hose? With my 9000iH it took a few seconds of cranking but fired right up using the supplied hose.
Mine actually takes more than a few seconds for the line to clear. I hold it open until I clearly smell propane. After that, it instantly starts.
PS - I LOVE being able to run it on propane - No gasoline residue cloggng the carb, no clean-up required. I added an outlet and pressure valve to the propane line coming into the house so I can run the generator for many hours off the main propane storage tanks, if needed.
   / Got a new Duromax XP10000EH Generator, propane question #44
Any good links/instructions to adding the line and pressure valve? I've a 250 gallon tank that we only use for hot water and use about 30% /year.
   / Got a new Duromax XP10000EH Generator, propane question #45
Love the idea of dual fuel… but what’s the cost like on LP? My inverter uses 2 gallons of gasoline for 12 hours of use, which is amazing
   / Got a new Duromax XP10000EH Generator, propane question #46
At low to less than full load, inverter generators are almost always going to be more fuel efficient than gasoline / propane generators and often better than even a diesel.
The best fuel efficiency (specific fuel consumption) for most engines is around 50-80% of load, near the maximum torque, but there are certainly exceptions.
https://www.gerrmarine.com/Articles/EnginePowerCurves.pdf
All the best,
Peter
   / Got a new Duromax XP10000EH Generator, propane question #47
When we build our next home, I plan to include a whole home LP generator since we will be there in our old age.
   / Got a new Duromax XP10000EH Generator, propane question #49
You might think about adding batteries. That would let the generator run efficiently while charging the batteries, and give you many hours of quiet time with power. You could even add solar...
All the best,
Peter
   / Got a new Duromax XP10000EH Generator, propane question #50
Sorry, I don't have any instructions. I had the propane distributor install it. They charged $15 (cash) and furnished the regulator valve, fittings, and labor to hook up to my 250gal tank as well but I don't think that's the 'normal' price. They just "happened" to have a used but good extra regular behind their truck seat :)
That was a 10 minute job. They set the pressure @ 12psi.
2019 CASE IH 580S QUAD TRAC TRACTOR (A52707)
2019 CASE IH 580S...
2008 Pierce Enforcer Ladder Fire Truck (A55852)
2008 Pierce...
2011 Freightliner M2 112 Tri-Axle Dump Truck (A55852)
2011 Freightliner...
2006 CATERPILLAR TH460B TELEHANDLER (A55745)
2006 CATERPILLAR...
2012 LAMAR TRAILER 20 T/A UTILITY TRAILER (A55745)
2012 LAMAR TRAILER...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
