Egon
Epic Contributor
I've had the same symptoms. Mine was the run cap shorted. Happened a few times before the ole 1976 Franklin gave up 2 years ago. If you have a ohm meter, and with the cap disconnected from the circuit on both legs, run an ohm meter between the terminals. I would bet it would show continuity with high resistance. Can do the same with the start cap to test it too.
:thumbsup::thumbsup:
