got a water well problem
   / got a water well problem
Quote Valveman, As long as the max pressure of the pump is less than 150 psi, the CSV125 will work fine.
The pump is 1hp with a 40-60 pressure switch. Where would the psi be measured, am I missing something? Will I have to measure PSI somehow somewhere?
And with a 40-60 pressure switch would I use a CSV125 60psi? also I can install it horizontal?
Richard
   / got a water well problem #22
Richard
The back pressure depends on the pump and the static water level. A 1HP, 10 GPM pump with a static water level of 32' will have a back pressure of 150 PSI. A 1HP, 7 GPM pump would need the static water level to be at least 192' deep to stay below the 150 PSI back pressure needed for the CSV125.
The CSV1A can take a lot more back pressure than the CSV125. Just let me know the GPM of your 1HP pump and the static water level and I will figure it for you.
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
2012 FORD 4 DOOR TAURUS SEDAN (A54607)
2012 FORD 4 DOOR...
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A53843)
2018 KENWORTH T800...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
