1stDeuce
My air filter was pretty clean so I blew it out with the compressor and put it back in.   Look up the agco p/n and see what cross references.   Google agco parts book and use the guest button to look up p/n's.
Appears to be leaking from the input shaft seal. Have you looked underneath to see if it's also leaking from the output shaft?
If it's just the input seal leaking I'd check for bearing slack. No reason for a seal to start leaking up there unless the bearing is getting loose.
Assuming the bearings are tight. Many, many brush cutter owners pump the gearbox full of grease rather than oil and keep running it.
