got to 250 hrs. with my MF1531 :mad:
   / got to 250 hrs. with my MF1531 :mad:
So in other words, the Kiotis that I didn't break are strong enough to handle the shock loads. They both had less power and are about the same size so that's why I thought less power= less broken stuff.
   / got to 250 hrs. with my MF1531 :mad: #22
Less torque equates to less shock,so yes.Broken PTO usually is a sign of hitting something solid that tries to suddenly stop the implement causing a shock to the system.The weak point is what broke.Bouncing the front end will cause the steering gear to take a shock and the weakest part broke,the link.The steering was probably damaged prior to the lawn work.bouncing across it at a fast speed probably finished breaking the link.Turning sharply or jerking a tractor around at speed will also cause steering gear failure.I won't mention the safety issues with this operational technique.
   / got to 250 hrs. with my MF1531 :mad: #23
You are making a lot of assumptions. Sometimes people just have plain bad luck with a certain brand or model. I know I have then went out and bought the same thing in another brand and had zero issues.
Chris
   / got to 250 hrs. with my MF1531 :mad: #24
Chris
True,but if someone understand what CAN cause failures, it will prolong the life of anything they drive or operate.He may have a LEMON.
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
2010 Honda CR-V SUV (A59231)
2010 Honda CR-V...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2022 BROCE BW260 SWEEPER (A60429)
2022 BROCE BW260...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
