got to be an easier way
   / got to be an easier way #21
For me, it's just as easy to hook up the shaft first, then the arms and then the top link. If I hooked up to it, moved it, then hooked up the shaft, I could have been tilling..... /forums/images/graemlins/grin.gif
The tiller when attached sets so close to the tractor its VERY hard to get into the PTO area.
   / got to be an easier way #23
The more I hear about it the more it seems like a 1 inch pipe about six feet long as a pry bar may be the easiest solution.
Egon
   / got to be an easier way #24
I'm going to try this,
1st get the 2 shafts put together
2d hook it to the the tiller
3d back the tractor down the area and try to hook it up
4th go for the rest of the 3pt links, bw
   / got to be an easier way #25
5th...sit down and have a beer. /forums/images/graemlins/grin.gif
   / got to be an easier way #26
gws -
had an identical problem with my FX24D and tiller. Very difficult to get everything aligned, and even when connected I only had < 1 inch overlap in the shaft - so little that as soon as the tiller lowered into the soil, the shaft came apart and broke. I had to replace it with a conventional shaft that I cut out of PTO stock, but - dimensionally - much more suited to my particular tractor/tiller setup.
   / got to be an easier way #27
Maybe step 5 was my mistake--I had that as step 1....and 3.....and 5. Talk about a 12 step procedure.
   / got to be an easier way #28
I "unload" my tiller on some concrete pads made from 2 bags of fence concrete left outside in the rain. Keeps it from bogging down in the muck, and also slides around some to line it up. but I too figured out that connecting the PTO shaft FIRST, then backing my tractor up into the lower lift arms of the 3ph works really well. I also loosen my "cinch chains" and use 2 bungie cords to hold my lift arms spread until I get back far enough to hook them up to the tiller.
Dale
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
1/2 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2 '' Wolverine...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A52472)
2015 DRAGON 137BBL...
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
LMC LOT NUMBER 141 (A53084)
LMC LOT NUMBER 141...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
