Got torque?
   / Got torque?
I have never had a wheel come of because of lugs nuts loosening up. I always use a crossing pattern when tightening them. I also do this with my 1/2" impact, but I don't use the highest of the 3 settings. I start with the lowest, 1. Then when it won't tighten any more, I go up to setting 2. I don't however, just let it hammer away until it stops turning. Instead, I watch the socket for a small amount of what I'd call "final seating" torque. My wife could take the lug nuts off if she needed to. I have helped many a person on the side of the road, usually women, that I don't think would have a prayer of being able to change their flat tire. The lug nuts seem like they were tightened to the max torque that the impact could generate and had Red Loc-Tite (sarcasm) applied to boot.
I also judge what I think will hold on a fastener by the size of the fastener. Small bolts, I am using 1/4" sockets or smaller wrenches. Medium gets 3/8"s sized sockets, and the larger get 1/2" or 3/4" depending on how large they are.
   / Got torque? #12
This question has to do with torque wrenches.
I know that to do a truly proper repair on a mechanical device, let's say a tractor :))); a person should perform the repair and use the proper torque on all the bolts and nuts set forth by the shop manual.
So when the rubber meets the road, where do you all stand on this?
I've done about a million hours of motorcycle work, which is full of small metric fasteners with relatively low torque specs. I have an inch-lb click torque wrench, and a cheepie beam wrench that I use torques higher than the 20 ft-lbs the the clicker can handle. I used to use a torque wrench on just about everything, until I learned what the various torques felt like with specific wrench lengths. Most nuts/bolts are properly tightened WAY before it "feels" right to most. I rarely use a torque wrench any more, still break it out whenever I feel like I might not have a good feel for the particular fastener.
JayC
   / Got torque? #13
I spend roughly 50% of my time at work torquing high pressure lines etc. generally speaking we use a torque wrench for everything above 7/8" studs. We always use an anti-seize of some sort( as per client requirement), for example a 7/8" stud properly torqued is at 250ft/lbs with anti seize . That same stud torque dry requires 893ft-lbs of torque to do the same seize.
   / Got torque?
Wow, that is quite a difference. Much more than I would have expected.
Does un-set loc-tite have any lubricating properties at the time of assembly? Just wondered if it was giving you a truer reading, or are those torque values listed in a shop manual expected to be dry?
   / Got torque? #15
What product number is in-set or it's properties? I looked at the loctite web site and couldn't find it!
   / Got torque? #16
I restore old tractors. I use a torque wrench on head bolts for sure. Also on bolts that are threaded into other cast iron parts of the tractor (bolster, axle housings, tranny and differential case, etc).
It's a real pain to over-torque in a situation like that and strip out the threads. Then you have to use a Helicoil, which can be another headache. I replace nearly all the bolts during a restoration, so you have to be careful since you're running new bolts into old threads that may have lost a considerable amount of their original strength (metals age by crystallation, etc).
Of course, for head bolts you have to torque them down enough to get the head gasket to seal properly. This can be exciting when you're reassembling a 60+ year old engine and pulling hard on your torque wrench--waiting on pins and needles for the bolt to start spinning in the hole after the threads fail:eek:.
   / Got torque? #17
I use a torque wrench whenever I have a torque value. I come from a family of mechanics and I guess it is sort of ingrained in me.
As to being able to "feel" the right torque, I don't doubt some can, I am just not one of them.
   / Got torque? #18
Take your torquing in stages and give time to "settle" between stages. Pay attention to material temperature cold steel is not very friendly to work with. Keep in mind that I am in Canada
   / Got torque? #19
Using a torque wrench for lug nuts is less to prevent them from falling off but from over tightening. In the old days people thought the tighter the better but now things like warping the rotors and breaking the studs are more likey results from not using a TW.
I have three and use them when needed but not as often as I should. First lesson is never use them for anything but torquing bolts and nuts, they aren't replacements for breaker bars. Secondly it's hard to have just one size, my Craftsman 1/2" goes up to 250ft/lbs. It's almost worthless for anything small. So I have a 3/8" ratchet and a 1/4" screwdriver style.
Most bolt sizes and grades have standard torque values that should be followed when a specific number isn't given. Yes I also have the calibrated arm and too often use it when I shouldn't. So just having them and knowing that you should use them doesn't mean that you will.
   / Got torque?
If one needs a variety to much all of the different ranges you might deal with, how good is good? I can't afford $1,000 just in _____________ (insert favorite brand) torque wrenches.
Does a $10 Harbor Freight special get the job done or is +/- 4 percent to much gray area? :confused:
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
19010 (A48082)
19010 (A48082)
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
