grab hooks on equipment for tying it down
   / grab hooks on equipment for tying it down #11
I don't have a grille guard on my T2320 but there are holes to bolt one to it. I drilled two of the holes, one on each side, to fit a clevis like this.
1 1/4 x 3 3/4 Straight Tractor Clevis
You can kind of see them in this picture
   / grab hooks on equipment for tying it down #12
I did the same thing. Works great.
   / grab hooks on equipment for tying it down #13
The frame on my XR3037HC does have holes pre-drilled that I could have bolted the D-rings to. However, where the D-ring would have bolted on the right side the exhaust pipe is right in the way for it to swing up. I didn't want to cut or bend the pipe which is why I mounted them on the brush bar.
   / grab hooks on equipment for tying it down #14
I would stick to a closed hook, D-ring, or chain around a solid portion of the equipment. Anything that has an open end to it such as a plain "hook" may allow the chain to come loose under slack. Such as a sudden back and forth movement or failure of another portion of the tie down system. Just my 2 cents.
   / grab hooks on equipment for tying it down #15
Here is what I did to mine
2012 Ford F-150 Crew Cab Pickup Truck (A53422)
2012 Ford F-150...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2012 Freightliner M2 106 Altec AM650 50ft. Bucket Truck (A55852)
2012 Freightliner...
2020 Case-IH 250 Magnum (A53314)
2020 Case-IH 250...
TORO TRX20 STAND ON TRENCHER (A52707)
TORO TRX20 STAND...
2011 Ford F-350 Knapheide Service Truck (A55852)
2011 Ford F-350...
