Grading scraper - which one?
   / Grading scraper - which one? #1
GregbkH
Wisconsin
2010 New Holland 3045
I've been thinking of purchasing a Land Pride Grading Scraper. Either the GS1572 or the GS2584.
The 72" weighs approx. 600 lbs and is rated for 25-50 hp and the 84" weights approx 822 lbs and is rated for 40 to 90 hp.
My tractor is a NH boomer 3045 rated at 45 hp. Which scraper would work best for me?
I do have a RBT3584 hydraulic rear blade (84") which my tractor can pull full of stone and dirt.
Thanks for the help
   / Grading scraper - which one? #2
Thanks for the help
IF you can pull an 84" fine, I'd get that one.
How wide are your back wheels spaced. Because you want something that will at least cover your tracks.
My back tires are just under 6' wide.
I will be using it to maintain my gravel driveway and easement. A little over 1/2 mile long. I also want to use it for leveling dirt in my yard. The dirt is mostly sandy soil.
   / Grading scraper - which one? #4
If I'm not mistaken the GS25 series is the heavy duty line. If you're plans are to occasionally do your driveway it could be a little overkill. I don't have one yet, it's at the top of the list for this spring though.
I'm curious what some of the others here think about having extra width. For a large wide area it would be fine but if you have a 10'(ish) wide driveway would something 7' wide hurt while trying to put a crown on the drive or help.
   / Grading scraper - which one? #6
Only if you're driving backwards. Doesn't matter going forward.
JayC
   / Grading scraper - which one? #7
Do you have a rake? You really want a rake for a gravel drive and/or spreading dirt/loam. Landpride makes a york rake with a flip-down grading blade that is pretty cool.
JayC
   / Grading scraper - which one? #8
I just went through this and ended up ordering a Grademaster Utility 7. It's 7' long and weighs 660 lbs, and was $1100 delivered to Tennessee from them in Mississippi. There is a thread on it down below here in the attachment forum. The LandPride 6' was almost $1800 delivered, but it does have an adjustable blade set from flat to crown and scarifiers. I have a HD Box Blade, so I didn't need something that could do that digging and leveling, I wanted something that puts a crown down.
Here is their website:
GradeMaster Grader Blades
   / Grading scraper - which one? #9
JayC
I guess it depends on how picky you are and how soft the ground/drive is when you do it.
Same as with a tiller.
If you track wider than the scraper, your final pass wont cover the tracks, and you will leave prints (or ruts if soft) that the scraper wont cover. And if your drive is a mudhole and soft like mine once you start working it, it matters:thumbsup:
   / Grading scraper - which one? #10
My Land Pride GS1572 cost me $1,400 total from my Kubota dealer (even got it in orange :p)
Not only are the blades adjustable up / down, but it has retractable tines for ripping up the dirt if that's of interest.
The blades are also angled to direct material toward the left of the tractor, aka center of the road/ driveway, for crowning. I'm not sure all grading scrapers are made like that.
This thing is big, heavy & strong ... I can only guess that the 2584 would be more of the same brute strength, but also a foot wider - although 6' is pretty darn wide. I think you can pull the 2584 OK, but there may be times when the tail wags the dog a little due to the weight, or traction suffers ... gonna depend on how compacted the material is that you're working with, how moist it is, etc, the same things that affect a 6' model or a box blade.
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2010 John Deere Gator UTV (A49461)
2010 John Deere...
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
1997 John Deere 8100 MFWD Tractor (A51039)
1997 John Deere...
