Grand L Radio Install
   / Grand L Radio Install #11
Hmmm.......been trying to figure where to put an XM radio?? Thanks for the pic's, reminds me of when I upgraded the speakers and took off the top. I also insulated while I had it off.
Hootie:
I thought about putting one of the various Dynamat applications on the underside of the roof to insulate and reduce noise/vibration, but I couldn't figure out how much clearance there was between the roof and HVAC components. It looked to me like the dead space up there was utilized as part of the ventilation/return for HVAC operations, and I didn't want to interfere with that.
Do you happen to know if the insulation still provides enough volume for proper operation, or have you experienced any problems?
Thanks,
Jay
   / Grand L Radio Install #13
Hello Jay.
I had the outer part of my roof removed (L4200)… You are right the space is used as the return air path. Hootie has a great suggestion about insulation, factory should have installed it. I used the ¼ inch thick bubble wrap looking stuff, it has foil on both sides, used in hotrod building and can now be found at building centers like Lowe’s and Home Depot. I used spray adhesive to apply to the inside surface of the top. This works great and has no adverse effect on heat or air, actually it improved the A/C to the point that I never use high A/C, even on the hottest days. During the winter the heat warms the inside of the cab instead of melting the snow/ice on the roof. KennyV.
PS... nice radio install /forums/images/graemlins/smile.gif, looks like they have not changed things from model to model.
   / Grand L Radio Install #16
Kenny:
I like dealing with FarmTek. Nice folks and prompt shipping too. Last fall, I bought a 32 x 16 x 78 foot clearspan building from them. It's a nice building and was cheap compared to a pole barn. I need storage for round bales and collected junk and tractors too. I think I'll do the roof on the M9 as well.
Sunflower Yard Decoration (A55758)
Sunflower Yard...
2007 Ford Five Hundred SEL Sedan (A55853)
2007 Ford Five...
2006 FREIGHTLINER COLUMBIA 120 (A55745)
2006 FREIGHTLINER...
2009 Lexus RX 350 SUV (A55758)
2009 Lexus RX 350...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
