Grapple Bucket on 3720
   / Grapple Bucket on 3720
</font><font color="blue" class="small">( D.
Yes, John Deere sells a 4:1 bucket for our tractor size. I have mentioned earlier in this post that I think WR Long makes a great 4:1 bucket. My neighbor had one on his 4410 and now has another on his 4320. All things equal, I think WR Long buckets are a little heavier duty than JD buckets. That said, I just bought a JD 4:1. The reason? My local dealer has almost exclusively sold Long 4:1's and wanted to get in and check out a John Deere one. Thus, I got a great deal on a new 72" 4:1 from John Deere. Since I do not use my tractor hours on end as my neighbor does, the extra heavy duty does not matter as much to me (although I still would have gotten the WR Long if price was closer for me). Once it comes in I will try to give the group a more direct comparison of the FEATURE differences between the two. The more I see them, the more I think any tractor would benefit from such loaders. See, I am really not going against the advice I mentioned to Michael, just broadening my horizons.
John M )</font>
John,
Since I'm getting the Long 4N1 bucket and you the John Deere, we can both report our experiences.
One of the main reasons I got the 4N1 Long bucket was that it opened wider than the 4:1 Deere. I will be interested to see if that makes any difference in real world use. I thought it might be able to pick up a larger diameter branch or munch up a wider bite of compost or dirt on the ground. But, having never used a 4N1 bucket before, I am just guessing. There's nothing like trying something out in real life to find out.
I'm looking forward to your reports.
   / Grapple Bucket on 3720 #32
John, If you decide to get rid of the tractor at a later date I will take your 4N1 off you (now that I can get to your house /forums/images/graemlins/wink.gif ). if you need to unload it. Those look awesome.
   / Grapple Bucket on 3720 #33
The Root Rake Brush Grapple, the RBG2 for compact tractors, is $1795. Weighs 365 lbs.
)</font>
I am surprised to see that this is the reccommended grapple for the 300cx. The website suggests this rake for loaders with a 1300 lb max lift. Doesn't this loader have a maximum lift far more than that /forums/images/graemlins/confused.gif
   / Grapple Bucket on 3720 #34
I think the weight of the grapple itself is why ... subtract it's added weight and ...
The 300cx loader's lift capacity is only 1598 lbs. The next size bigger grapple, the RGB-60, weighs 567 lbs. It's a trade off.
On the small 300cx, I'd rather have the greater net lifting power that the RGB2-60, which only weighs 365 lbs., would give.
My guess is that the RBG2 is plenty stong enough for the 300cx loader's lifting range. Moving up to the heavier duty grapple may only result in less net lifting capacity.
   / Grapple Bucket on 3720 #36
I've enjoied reading about our 4n1 buckets and grapples on this post. I work for W.R.Long. You are welcome to contact me with any questions. We make all our products per order, so that is one reason our delivery is normally 2 to 3 weeks. I'm always interested in improving our website so any comments are welcome.
Thanks,
Nelson nlong@wrlonginc.com
Nelson,
I found your website very helpful. I especially liked the gallery section where I was able to look at multiple, high-resolution photos of your products from all angles.
Also, when I called to ask questions, you were very helpful. The result, I've got a a 4n1 bucket on order with you now.
2017 GRAND DESIGN RECREATIONAL MOMENTUM (A53843)
2017 GRAND DESIGN...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2012 Mazada 3 Sedan (A51694)
2012 Mazada 3...
