Grapple Build, suggestions for bushings
   / Grapple Build, suggestions for bushings #21
They sell different size collars at TS, I would use them and weld them to the outside of material, add zerk and call it good.
Most collars are made of carbon steel like C45 (dont know the US equivalent) which is meant to be machined, not welded. The higher carbon content makes it prone to crack right beside the weld, in the Heat Affected Zone (HAZ) I was once asked my opinion about why these things cracked off the frames, in a company i just started working for. I asked them, look up the material, its most likely C45. And it was. Replaced by DOM tubing and no problems since.
   / Grapple Build, suggestions for bushings #22
good to know, thank you.
   / Grapple Build, suggestions for bushings #23
Yes, good information. Thanks for posting.
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
CAT 336E (A58214)
CAT 336E (A58214)
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
2018 CATERPILLAR 289D SKID STEER (A52709)
2018 CATERPILLAR...
Ford 8340 (A53317)
Ford 8340 (A53317)
