Grapple Failure
   / Grapple Failure #172
Looks to me like "Titan Attattachments is just a distributor.
Could be wrong, but that would be an indirect line to a failure resolution.
Hmm STF,
http://www.tractorbynet.com/forums/attachments/180624-new-titan-grapple-2.html
Read the first post and post #20. 'Guess nothing is perfect.
"Ya's pays ya's moneys and takes ya's chances"
My thought exactly-went to their website-no reference top a corporate address or facility. when I bought my "Econo 48" Wildkat" I had done some research on this site. Also recalled a post from a gent who went to their site-he was impressed. I did the next best thing I could-I googled earth the address-sure did look like a manufacturing facility. I don't like doing business with "marketing" companies as for sure that says to me no clue where the next order is coming from.
By the way, pulled my records. Bought mine 2/12, and the price without attachment system (I wanted to put my own JD system on) was 510 bucks- freight brought total to 670. Shortly after I bought mine, I know they started bumping price up.
   / Grapple Failure #173
View attachment 367818View attachment 367821View attachment 367824View attachment 367825View attachment 367826Wow do i feel guilty- I'm one of the wildkat 48 boosters who has published many "endorsements" on this site. My point- **** of a value. I paid under 700 bucks delivered to Mass. And guess what? I broke mine too! Not wildkat's fault- my fault.
A lot of good comments here by CalG, Puckginder 85, and Island Tractor to name a few. I don't know how you damaged yours, but I suspect the hydraulic cylinder had nothing to do with it.
What I did was foolishly try to "hog out" a good sized boulder by rolling the grapple forward, opening the jaw, then lowering the upper grapple on the lip of the rock and backing up-and I'm talking about 60 HP (4720 cab), loaded R-4's, and about a 500lb weight block that is adorned with about 60' of 3/8 chain. Next thing I knew the grapple in the "closed position was about 10 or 12" from closure.
Remedy? I took the cylinder off and used a heavy chainfall to pull the grapple to the closed position. then I did a half assed repair by welding the back side and adding a couple of gussets to front. I will beef up the back side when I get a chance with some angle across the top,
Attached are pix showing the two breaks, and three shots of my quicky fix. Also a couple of pix "in action". IMO still a good value! Just have to use your head
X2. In fact, I believe I am the one that originally introduced the WildKat 48 to this forum. I think I got an early prototype with two upper jaws and (for under $600) and I've had absoutely no problem with it at all. From my perspective, it was a great buy and I'm completely satisfied. If it were to fail as the OP's did, I'd just weld it up, no problem and still be satisfied.
   / Grapple Failure #174
I looked through this thread, but I didn't see a mention of the exact model being discussed. I copied this description from the manufacturer's website:
48" Mini E-Series Grapple
*Fits Toro Dingo, Thomas, Ramrod Finn, Ditchwitch, and more! - or Bobcat 463/S70 and MT55, MT50
24" high & 31" deep with 3/8"steel, 3 1/2" tubing, and a tie rod cylinder
420lbs $999
Is this the right grapple?
   / Grapple Failure #175
420lbs $999
I doubt it as the Dingo has a smaller quick attach as far as I know. It might be very similar though but with a skid steer mount.
   / Grapple Failure #176
420lbs $999
Agreed. And the link provided early on was no help to me. It would be nice to know exactly which model is being referenced so possibly a better evaluation could be performed. Also early on I thought I saw a post referencing ~ 350#? If this is true, it would be a lightweight model.
   / Grapple Failure #177
Since it is the only 48" grapple that matches the photo in the OP's first post, I think you're right - they must have made it at one time with a skid steer mount. (I don't see anything on the website that shows the 48-inch "economy" grapple available for tractors or skid steers.) The manufacturer may have decided that the grapple was under-engineered for SCUT or CUT use but, rather than beef up the construction for use on SCUTs or CUTs, they now sell it only as a Dingo-type implement. A Dingo is unlikely to generate the same stresses on the grapple as the OP's tractor (which is an L3200 with LA524 loader?). It may be that the design flaws that many TBNers have pointed to are not a concern when used on a Dingo.
Just speculation ...
   / Grapple Failure
I'm pretty sure it is the E-Series, or very similar to it as it is the only 48" grapple on the site now at least. I don't recall the specifics on the website when I bought it but I did call them and discuss it with them prior to purchase and told them I was looking for a 48" grapple for a Kubota L3800 with LA524 loader with SSQA. I think the price was $899 when I bought mine but I was very clear about my machine specs as I was more concerned about it fitting properly at the time than strength as I had read pretty good reviews on this site and had not seen the other failure thread. I also don't think they custom fabricated it as they turned it around pretty quick as I recall once I placed the order. There was no discussion on the grapple being undersized or under-designed and ample opportunity to do so I believe as I think I ended up speaking with them a couple of times prior to ordering.
Also, can a Dingo, Bobcat 463 or Ditchwitch even lift a 420lb grapple?
   / Grapple Failure
I reached out to Wildkat via email and just ask them if the grapple is/was under-designed for my machine. If that were the case, it would have been preferable to know it before I purchased but I'd consider upgrading to more appropriate unit if they would apply my original purchase price as a credit to the new one. If not, then I'll just have to reinforce as required as many people offered very good suggestions on how to do so and my neighbor did agree to swap me his welding time for some tractor time. I probably could repair this cheaper than the shipping charges as well but my neighbor did say he felt a lot less comfortable trying to repairing this than he would welding on support pieces to reinforce a new one.
After this happened and I was looking around on the EA website at their new grapples, I did notice they gave a very specific HP range on their 48" model which would push me into the next size up if I were buying one of theirs. I appreciate that actually because we all want the appropriate tool for the job. Due to the reviews on this grapple (don't feel guilty, a good review is a good review), and the perceived lack of concern over the machine size when I purchased it, I truly believed I was doing just that. ~$1000 is a lot of money to spend on a tool and it never occurred to me that I was somehow skimping out. I still believe this is the appropriate size grapple for this size tractor, just not sure about the execution and design. Most of these Heavy-Duty grapples are very heavy and clearly designed for skid-steers or much larger tractors with much greater lift capacities.
   / Grapple Failure #180
It may actually be less costly for them to give you credit towards a bigger / beefier / more expensive grapple, so they might agree to that.
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
UNUSED FUTURE 32" HYD TILT MINI EXCAVATOR BUCKET (A51244)
UNUSED FUTURE 32"...
1977 Allis Chalmers 7060 Tractor (A50514)
1977 Allis...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
