Grapple Opinions Revisited and my Swiss-Army-Knife Bucket
   / Grapple Opinions Revisited and my Swiss-Army-Knife Bucket #1
NCMau
NC
MF 202/Ford 8N
Few weeks ago I asked opinions from the board for a simple grapple positioning and profiling I had in mind to build. Well I finally completed it and it turned out just what I was hoping. This may not be for everybody but for me suits my purpose well.
The claws consist of 3/4" x 2-1/2" and 1-1/4" stock welded and bolted with grade 8 and pipe spacers to provide 6" spacing . The assembly weighs about 95 lb. and it can be removed with two 1" pins. Since it needs to be lifted only an inch or two above ground, It can easily be mounted and dismounted even for a 74 year old fart like me. When removed, the 2 x 10 cylinder remains in place mounted on the bucket and it doesn't interfere with anything that I am aware of, so far.
The bottom of the claws consists of two bolted scarifiers (chisels removed) that can be moved up or down . So far I am okay where they are but I am still experimenting and if there is a need, the flexibility is there.
As shown in the pic, I used a 2" clevis adapter mounted sideways to hook up the assembly with a 1" pin. (You just can't beat these 2" receiver systems so versatile. I use them a lot).
The short 19" forks slide in the bucket and secured at a fixed location with one bolt to the back of the bucket. The exact profile makes it firmly engage into the bottom of the bucket. For the most, I use the short forks but if I need longer ones, I slide the 36" 2x4" sleeve adapter, tight fit with spacers... again, one bolt.
The sickle bar I built few months ago mounts in front of the bucket with two 5/8 bolts grade 8 bolts. This is a light duty bar taken from a walk-behind Gravely mower capable of cutting small twigs and vines in my wood trails.
The bucket boom is fabricated with 2" pipe I had laying around. It has a 3/4" rod thru the bucket side walls for keeping it in place. Even though the pipe has a 2" dia. the right placement of the 3/4" holes on the side walls prevents any looseness. Not shown, a chain that connects to the bottom of the bucket to prevent up or down movements.
I had to replace the existing 2-spool valve with a 3-spool. Before I bought one, I inquired the hydraulic side of TBN. Since I have a 7 GPM PTO pump, the suggestion of using 8 GPM valve came from J.J., and it was a good move at that. I have now much smoother hydraulic control than I ever did with the old two-spooler (probably a 20-30 GPM). I would have guessed the bigger the capacity the better flow/operation you have. You may have better flow but not better operation. Learn something new every day.
The whole project including hoses, fittings, cylinder, valve and some metal was around $400.
   / Grapple Opinions Revisited and my Swiss-Army-Knife Bucket #3
Looks pretty usefull! I could use that thing!!! Thanks.........
   / Grapple Opinions Revisited and my Swiss-Army-Knife Bucket #4
Looks more like a Jack the giant killer tool
   / Grapple Opinions Revisited and my Swiss-Army-Knife Bucket #5
Glad to see it as built, Looks good. I remember the drawings from your original thread. :thumbsup:
   / Grapple Opinions Revisited and my Swiss-Army-Knife Bucket #6
I like the grapple especially because I have been thinking about one for a few years.
Just an observation: It appears that your rear tires are mounted backwards.
You're right easygo. It was my screw-up when I painted them. I have been delaying the change for a brake job... one of these days!!!
   / Grapple Opinions Revisited and my Swiss-Army-Knife Bucket #8
Well, now you have more traction backing up! :thumbsup:
I turned the front ones around on the V518 when was removing silt with it. It did make a noticeable difference backing out of the slippery stuff.
   / Grapple Opinions Revisited and my Swiss-Army-Knife Bucket #9
Just my opinion, but I'd like to see you work on your bead control a bit more.
   / Grapple Opinions Revisited and my Swiss-Army-Knife Bucket #10
Nice. What is that, a 4' sickle bar? Can you post up some details on that?
   / Grapple Opinions Revisited and my Swiss-Army-Knife Bucket #11
Nice MF! :thumbsup:
you mean.... I won't get a job welding gas pipes? Shoot!!! I am well aware that my beads are not beauty contest material, but as ugly as they are, they haven't come loose yet. Anyway, when possible I always complement my welds with bolts. Just makes me feel better.
   / Grapple Opinions Revisited and my Swiss-Army-Knife Bucket #14
Thanks for taking my constructive criticism with a light heart. I respect you for that. Couple of thoughts: could your rods be wet or are you not using a 7010 rod? Rods are surprisingly moisture sensitive and they will go bad if not stored in a sealed container. The 7010 is a more user friendly rod. A 7014 is even easier to use, but almost impossible to find.
Thanks. I always appreciate constructive criticism. The only type rods I use is 6010. I inherited a box way back and that's all I have been using. They seem to be working okay for what I do. I guess there are not as moisture sensitive.
BTW my bead are not always ugly, actually sometimes are halfway decent. I guess that depends on the moon and my mental state.
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
2022 BOBCAT T770 SKID STEER (A60429)
2022 BOBCAT T770...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
RoGator RG1100C (A61307)
RoGator RG1100C...
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
