Gravel Driveway Advice
   / Gravel Driveway Advice #31
I was thinking about installing this on mine, I have ove 15% slope at one point. how often do you have to clean these out?
thanks
   / Gravel Driveway Advice #32
Depends on how many leaves you have. The sand/silt just forms a 1/4th inch layer on the bottom and does not affect performance. Leaves will clog it some until they all quit dropping.
Also, if you are not careful when blade-ing the road you will scoop gravel in there.
   / Gravel Driveway Advice #33
Here are the pic's of my trough....still working like a charm after a lot of rain(sorry it took so long):
   / Gravel Driveway Advice #34
Interesting. I never seen that before or even thought about it. I can see where that would be a lot cheaper and easier then a culvert.
Eddie
   / Gravel Driveway Advice #35
Eddie culverts work great as long as a crown is maintained. It's hard to tell from the pic, but that water break is just after a steep section & curve, then down another moderately steep section where the tractor sits. Water was getting in the wheel tracks after they compressed a tiny bit, running down the first section & actually making the turn to really take off down the last section. The water break completely negated the water effects making my maintenance job easier.
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
12FT X 20FT LIVESTOCK METAL SHED (A58216)
12FT X 20FT...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56436)
2022 Brush Wolf...
