grease fitting ???
   / grease fitting ??? #1
glmf
Southern Maine
CK20HST
does anybody know if the Kioti grease fitting are a standard metric thread, thought I read on here they were a dealer only item but not sure. Did a search to no avail. The fitting on my KB2365, last one closest to the bucket is impossible to get at, needs to be changed to a 90 degree fitting then it will be easy. Thanks guys
   / grease fitting ??? #2
I knocked that one clean off mine! They are metric, I found them at NAPA. My memory is going, but I think they were 10 mm, but I would pick up some 8's too! :p
   / grease fitting ??? #3
Napa and Harbor Freight usually has assortments in metric and domestic threads...
I would think the 8 or 10 above poster is referring to is likely the wrench flats- which isn't the thread size.
10 mm grease fitting would be huge---just think of a 9mm bullet and add another mm.
I need a better grease gun tip that doesnt include the words "Made in Tiawan"---present one gets stuck on my loader fittings requiring wrestling to get the gun off.
Possibly in part because fitting are recessed in a hole.
   / grease fitting ??? #4
Don't know if it helps but I just checked the manual for my KL122 FEL. Grease fittings are listed as 1/4-28. Yes, that's SAE (in metric I believe this is M6x1). Buying a mixed (SAE/Metric/various small sizes) assortment might be a good investment.
   / grease fitting ??? #5
A grease fitting assortment should be mandatory accessory that comes with a tractor. :) The best thing to do is buy a little grease fitting assortment that has standard and metric fitting's in it that way you know you will alway's have the correct size.
   / grease fitting ??? #6
I have had the same problem with finding the correct zurk fitting for the Top Link on my DK35. I bought a set of metric's at Rural King. Very Close but would not fit, I went to the autostore and found a SAE that would screw in but was just a little loose. Went the the Kioti dealer, and what ever he gave me, won't work either, I think they were metric, the same size I got from Rural King....
My next step is to take one off the tractor, go to the dealer with caliper in hand. Nothing is easy anymore...
   / grease fitting ??? #7
I know on auto front end parts sometimes they just drill an untapped hole and supply a self tapping fitting---That is a possibility if the hole is now some size not found in nature.
thanks guys, will do on buying the assortment and hope for the best, don't want to leave that pin on the hoe, gotta keep this thing for a long time!
   / grease fitting ??? #9
I know for a fact that the grease fitting on the inboard joints of the steering rams that hang down in harms way are not SAE or meteric. Some goofy british thread that was only available at a tractor shop and in my case a Kubota shop supplied a zerc from a Kubota trackhoe that fit perfectly. I bought two.
That fitting is not standard and wasn't found in my hadny dandy tray of of metrics or any zerc at NAPA. Lots of wasted time before I finally went to the Kubota place.
   / grease fitting ??? #10
Are you sure it's not a self threading metric or SAE? These tend to cut the threads a little larger than are used on normal fitting's. Some equipment manufacturers use self tapping fitting's because it removes one step from the manufacturing process.
   / grease fitting ??? #11
I just came in from the shop. The box of zerks that I bought at NAPA has 10MM X 1 printed on it. Yes, they are large, kinda look like 1/4" pipe threads, but they screwed right in my Kioti backhoe. I am the original owner, so the zerk area has not been modified. Until I hit the darn rock! ;)
   / grease fitting ??? #12
I had the same problem trying to find zerks locally for my CK30. On my last wish list from Wallace Tractors I asked for a variety set of commonly used Kioti zerks. I'll be darn if they didn't send me a package of about 8 or 10 assorted zerks for a small fee of course. I haven't had a chance to break into the package and replace the broken one on the front of the front axle. It hasn't been due for a greasing since I got the zerks. I'll let you know if the right size is in there the next time I grease her up.
   / grease fitting ??? #13
Hmmm. seems huge! Good thing for assortments... they save us 10 trips back and forth for the one or two pieces we need in trade for some unused product we can sell at a garage sale someday :~}
   / grease fitting ??? #14
I made a boo boo. The package of zerks is not a Kioti product. It looks like it has a little tractor logo with a Tisco label. It says they are metric but made in America. I'll pull one of the old zerks and see if it matches any of the ones in the package tomorrow.
   / grease fitting ??? #15
I don't know if it helps any but I had a similar problem and stopped at Smitty's in Weatherford, Tx. last Sat. and Virgil told me that Kioti uses two types of zerk fittings. One is the standard screw in and the other is a drive in that you install with a socket and hammer. You can tell because he drive in has threads that are circular. That explains why I couldn't get a threaded zerk to tighten up in a drive in hole. I often have experiences that require me to apply my palm to my forehead in an abrupt manner.
   / grease fitting ??? #16
Wow! XPlainsDave's post is enlightening but disturbing. No wonder you guys are having trouble :eek:
OK, so last thought / suggestion here (I did this for my FEL). After removing the problem zerk (or in my case, NO zerk), drill the hole out to the tap size for whatever zerk you want to put in, tap the hole, screw in the zerk, DONE ;)
   / grease fitting ??? #17
The problem with not being able to find proper Zurk's for my dk35 is still elusive. Went back to dealer today, and they gave me what they say is the correct fitting, which they indicated as a 10 mm. They didn't charge me for the fitting, but apparently not the correct one, cause it doesn't fit.
Took a and measured the Outside diameter of the threaded portion. The Defective Zurk measured 0.382"
Another Zurk off the tractor measured 0.383"
The Zurk given to me by Kioti dealer 0.391"
Under magnification, the thread spacing seems to be the same, as the two zerks appear to mate together pretty closely.
The Kioti fitting off the tractor, is longer by about 1/4" and appears to be more tapperd at the start of the fitting.
Does anyone have some insight on to what is going on. ... :<(
   / grease fitting ??? #18
The size is correct, the problem is that the one that came out is a metric pipe thread, it is slightly tapered. I have not been able to find a source for them. work the old one in and out of the hole a little to expand it or buy a 10mm tap to open it up. I have done both.
Tom
   / grease fitting ??? #19
Are you conerned that perhaps the hole into which you are trying to place this zerc has been buggered? If you have doubts about the hole then verify its integrity by swapping a zerc from somewhere else on the tractor.
Next time you're at the dealer, ask him to give you one from a tractor on his lot and have him figure out how to replace it.
   / grease fitting ??? #20
Just be sure to use the socket! Some doofus at the place that built my dump trailer hammered a bunch of them in right on the top without a socket. Buggered them up so the grease gun won't seal to them, then being press fit they are hard to get out to replace with new ones:cool:
9000 (A47477)
9000 (A47477)
John Deere 1025R (A53317)
John Deere 1025R...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
2017 FORD E-350 SUPER DUTY 16' BOX TRUCK (A60430)
2017 FORD E-350...
