grease fittings
   / grease fittings
The weather should be warm this weekend so I will have at it again. I am going to make the access hole big enough to get an end wrench on the fitting. and get a swing on it. The hole now is only a little over an inch in diamater. I can grind it out some.
   / grease fittings #12
I have a hard time believing there isn't a better way than to make the hole bigger. Swivel head gear wrench perhaps?
   / grease fittings #13
The majority of zerk problems are due to old dry grease.
Heat cures most times or a light tap on that little tiny ball at the end of the zerk also helps.
When heat and tapping fails, simply replace as zerks are like a 'dime a dozen', well not quite but really cheap.
   / grease fittings #14
Everybody has, at one time or another, had a "difficult" zerk.
Not me ever, the grease just flows beautiful and I never get greasy hands. Now I need to go and feed my unicorn:laughing:
   / grease fittings #16
What a clever idea! Any idea what these things cost? I can see all sorts of places where not using a torch would be a great thing!
   / grease fittings #17
Want to say it was under $400, get an extra one of the soft wire rap ends. I use it more than I thought I would.
   / grease fittings #18
$499 on Amazon for MD-700 .... ouch
But so awesome... if you work on rusted equipment most of the time.
   / grease fittings #19
Try a heat gun. This one is on sale this weekend for $8.99. I have one that works very well.
1500 Watt Dual Temperature Heat Gun 572°/1112°
If you get the grease zero out, use a small screwdriver and dig out as much of the hardened great as you can. Blow out loose prices with compressed air. If you have some Fluid Film squirt some into the fitting hole and let it soak for an hour or so. Work brake pedals a few times during soak. Add more fluid film. Replace grease fitting after assuring that it passes grease or install a new one. Try your grease gun again.
Sent from my iPad using TractorByNet
202481 (A54757)
202481 (A54757)
Deere 35P (A53317)
Deere 35P (A53317)
LOT: (1) Craftsman Shop Vac, (1) Dewalt Shop Vac (A59076)
LOT: (1) Craftsman...
Frontier 3 Point 8' Disk Harrow, S/N 1XFDH13XVK002234, 22" Disks, Asset# 64 (A59076)
Frontier 3 Point...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
