Grease for hitch balls
   / Grease for hitch balls
Someone once asked TBN members for advice in manual or hydrostatic transmissions. My favorite reply came from the person who cautioned him that " IT'S A RELIGION ". I had no idea things would be the same with greasing hitch balls. ☺
Thanks to everyone for your replies.
   / Grease for hitch balls #52
And why wouldn't it tend to tighten up the hitch ball/nut on opposite turns?
I don't use city slicker grease.
TBS
" I don't use city slicker grease".
You probably do not tow for thousands of miles each year either.
   / Grease for hitch balls #53
   / Grease for hitch balls #54
I started greasing the ball when I noticed gall marks on the ball. It's a GN with about 9,000 pounds of trailer. Before greasing the ball, I wipe it clean of collected grit & dirt. Then the GN coupler keeps it covered, until unhitched.
   / Grease for hitch balls #55
Just stoping the squeaking gooseneck and ball is worth the grease. Minor effort. Amazing how some think its a lot of work and hassle. Personally pull a gooseneck loaded close to max (at least) on most days. Rest of the time the 2 inch bumper maybe, the 2 5/16 bumper usually. A bit of grease is easy and cheap and sure not notable as a issue when working. Not wearing Sunday clothes at work.
Interesting on the 5th wheel remarks about grease is ok because of the large surface. That just translates to less pounds per square inch. Most people still seem to grease them or install the teflon plates or whatever.
Stoped the occasional gooseneck ball loosing up years ago when I switched to the peg type gooseneck balls that insets into the cross member mount.
If your not having problems then yahoo, no issues. For those that are it can be nice to have the info.
Many people do not seem to even pay attention to the weights stamped on the balls and hitches when purchasing or hooking up.
   / Grease for hitch balls #56
Good post!!! Especially the last part!!! :)
   / Grease for hitch balls #57
The Reese Ball Grease made a big difference in the wear on the 15K forged ball towing a 13k plus toy hauler. Also cleaning the coupler with a paper towel with WD40 to get the grit out helped a lot. Oregon Coast Dunes have sand blowing everywhere.
David
   / Grease for hitch balls #59
If you don't want to use grease, but, still want to lube your balls. Try wax. I've been using it on a grading chain for 30 years and its holding up well.
I like that idea. Is this a special kind of wax?
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
(2) CARLISLE AT25X12-19 TIRES & RIMS (A58374)
(2) CARLISLE...
PITTSBURG 2R CULTIVATOR W/ ALL FEET (A52708)
PITTSBURG 2R...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3 Ton Crane Service Truck (A55973)
2017 Ford F-550...
