grease points MF 253
   / grease points MF 253 #1
mauricem
QLD AUSTRalia
MF 253
My service manual says to grease the steering column and clutch pedal bearing, trouble is I cant find any nipples on either of these?
All the other greasable points Ive located no probs. The tractor has power steering if that makes a difference.
I have the factory service manual but unfortunately not the owners manual.
1998 MF 253 2WD 8spd
the image below shows steering column lube point for 240 which according to my manual I should have but do not ;)
FWIW other grease points are shown on this page
http://www.tractors.pk/grease-point-on-mf-tractors.html[/url any help much appreciated
bump! 200+ views! 0 answers :)
Any owners of 240 series welcome to chime in? Should be the same setup as the 253.
Happy to swap a pdf of OEM service manual (not the dodgy I&T one) for an operators manual if that helps anyone :)
   / grease points MF 253 #3
i have a digital version of the 200 series manual if that will help. is the op's manual a 253 or 240?
2020 Ford F250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F250 4x4...
John Deere 4600 (A53317)
John Deere 4600...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
