Grease Testing
/ Grease Testing #21
. In that case, I like a good moly grease with a Timken load test of at least 80 lbs, but better would be 100 lbs. The soap base doesn't bother me much as its job is to hold the lubricant, but I try to stick with one type to avoid incompatibility.
What greases have you found that have a timken test that high???? Highest I have seen was 70????
But all that really measures is the EP property of the grease. And there are also the 4-ball scar and weld test that ALSO test the EP properties. And even comparing greases, these gan be different. One may have a higher timken test but a lower 4-ball wear and weld test:confused2:
But if you NEED an EP grease, higher #'s are better for the 4-ball weld and timken load tests.
But that isnt the only thing that matters. Those greases may NOT perform well in something that is NOT an EP application.
I had a thread on here I started about a year of so ago, and I listed a bunch of greases and gave some specs of alot of them. Mostly stuff we use at work. But unfortunatally I cannot find it. I dont know if it got deleted or what. But even going back through my profile of the threads I have started and it is nowhere:confused2:
/ Grease Testing #22
Just spent another few minutes looking and nothing???? I know it was on here, I dont visit any other forums. I know some of the greases I references were tribolube, fuchs renolit moreplex, and even searching them two I get nada. :confused2: Mods??????? Where did it go????
/ Grease Testing #23
For some reason it was removed back in May of last year. :confused:
It is now back. Here is a link to it.
http://www.tractorbynet.com/forums/oil-fuel-lubricants/206044-grease-lets-get-technical.html
:thumbsup:
