Greasing FEL control lever on B2920
   / Greasing FEL control lever on B2920 #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
My FEL manual says to grease the control lever when I grease the pivot points on the loader every 10 hours. I couldn't see a fitting or an effective way to grease the lever, unless I am missing something. Anyone know how it should be done?
   / Greasing FEL control lever on B2920 #2
I have the same trouble on my BX,but I don't think it has a fitting. I lifted the boot and sprayed some lubricant on the joints, but it doe not last long.
   / Greasing FEL control lever on B2920 #4
Good question did my fel today and realized te same thing.
   / Greasing FEL control lever on B2920 #5
Just use a little oil from an oil can on the control pivots.
I honestly haven't done mine in a long time and at 500hrs I'm starting to get quite a bit of slop in the joystick. I'll probably have to replace the pivots in another 500hrs or so.
In hindsight it should probably be done about every other greasing.
   / Greasing FEL control lever on B2920 #6
I also use fluid film to lubricate the FEL control lever linkage. I used to use white lithium grease but have found that fluid film lasts much longer and smells better to boot!!
   / Greasing FEL control lever on B2920 #7
Where do you get access to spray it? do you go through the top or under the fender?
   / Greasing FEL control lever on B2920 #8
On my L3400HST it is pretty easy.. just lift up the rubber boot and spray and put it back.. about a 30 second job.. but YMMV
James K0UA
   / Greasing FEL control lever on B2920 #9
James K0UA
Just like James said. The bottom of the rubber boot is grooved, just pull it up and out of the way and spray the linkage down.
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59905)
2017 VOLVO VNL64T...
18ft T/A Flatbed Trailer (A59231)
18ft T/A Flatbed...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
John Deere StarFire 6000 (A59814)
John Deere...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
John Deere 25A Flail Mower Tractor Attachment (A59228)
John Deere 25A...
