Great idea for laying pipe or cable...
   / Great idea for laying pipe or cable... #11
The debate is between:
1. Leaving the spool of wire at the stating point and feeding the wire into the ground entry hole while pulling the entire wire (by its end) through the whole trench made by the subsoiler
2. Leave the end of the wire at the starting point and feed the wire/pipe off the tractor through an attached curved pipe on the subsoiler into the trench as you move.
Method 1 is theoretically limited by the friction of the ground on the wire vs. the tensile strength of the wire.
Method 2. is theoretically limited by the amoung of wire you can carry on the tractor and the friction on the wire as it goes through the curved subsoiler pipe.
   / Great idea for laying pipe or cable... #12
Chris,
#3, you can actually lay the wire or flexible pipe out in front of the tractor in the path you want to bury it, and loop it up over the tractor's hood & over the ROPS and then down into the pipe connected to the back of the sub-soiler. By doing that, if you have very long runs, you don't have to worry about trying to mount a spool on the tractor large enough to hold the wire, and you don't have to try to figure out how to carry the flexible pipe.
   / Great idea for laying pipe or cable... #13
Agree with #3. I saw a post here where a gent did that. He put some C-clamp vise grips on his ROPS top to guide the hose.
Looked slick to me.
ron
   / Great idea for laying pipe or cable... #14
Hey Surfran,
Thanks for the link to the pic resizer. I downloaded it and resized the pipe plow picture. The picture was taken at the end of a run of 3/4" pipe. Another picture follows that shows another perspective.
The subsoiler is a converted tool bar scarifier from an old Allis Chalmers dozer. It has slots for removable plow feet. The feet consist of 1" x 4" steel bar with a notch at the top to wedge them into the slots. You can see a couple of unused wedges dangling on chains. The front edge of the plow is 1/2" steel plate sharpened to slice neatly through the sod.
The plow is hooked to my Ford 7600, and you can see 4 pieces of RR iron hanging on it for extra weight. Since the plow foot is not parabolic, it does not draw itself down into the ground. It puts the pipe about 12 inches deep which is way below frost in these parts.
The plow foot is mounted in the center position in the picture. If I need to place the pipe close to a fence or building I insert the foot into a slot at one end of the toolbar and it runs in the tire track.
You guys need to get away from the idea of laying roll pipe and adding curved guides on the back of the subsoiler - just rig up one of these and lay real pipe instead!! /forums/images/graemlins/wink.gif
gabby
   / Great idea for laying pipe or cable... #15
Here's another picture of my pipe plow setup.
gabby
</font><font color="blue" class="small">( The debate is between:
Method 2. is theoretically limited by the amoung of wire you can carry on the tractor and the friction on the wire as it goes through the curved subsoiler pipe. )</font>
Doc,
Your statement "is theoretically limited by the amoung of wire you can carry on the tractor..."
made a ligthbulb go on in my mind. If you ran a lot of product like this, you could make a <font color="green">loader attachment to carry cable reels</font>. Then you could feed the cable/hose etc. over the ROPS and into the subsoiler.
That would make it fairly tidy to install, and it would be self-contained.
   / Great idea for laying pipe or cable... #18
I have been follwoing these threads and am anxious to install a sprinkler system in my lawn but am somewhat confused. I can see how this would work with wire or cable and or flexible pipe but I dont see how it would work with PVC as some have stated they are using. Are you gluing all the joints together and laying them down behind where they need to be buried and then pulling them in?
If I am going to do this for a sprinkler system the only way I can see to do it would be to plow under the whole pipe and then come back and dig it up where I need sprinklers and cut the pipe and install it that way?
I really like the idea of doing this with my tractor and not having to rent a trencher but I guess I am used to having an open trench to work with and with this method that is not the case.
   / Great idea for laying pipe or cable... #19
I plan to use something similar to lay in a sprinkler system this summer. My plan was to dig some holes where the heads/junctions will go, as well as one for the valve boxes. Then I would pull in poly pipe in a connect the dots type deal.
Anyone see any flaws in my logic???????????
Thanks.
ron
   / Great idea for laying pipe or cable... #20
That should work. I would get some marking paint or something and connect the dots with paint before trenching because I could easily see getting off a few inches with the tractor and missing the holes.
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
Blue-Jet Liquid Fertilizer Applicator (A51039)
Blue-Jet Liquid...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2005 Construction Trailer Specialists BDT-40 Bottom Dump T/A 40ft Trailer (A49461)
2005 Construction...
2022 Mack MD Rollback Truck (A50323)
2022 Mack MD...
